Oil Viscosity?
Old 06-03-08, 06:48 PM
Lzam
Lzam's Avatar
Question Oil Viscosity?
I bought my 96 LS 400 with 78000 miles car now has 109000. Question is I don't know what kind of oil was in it before I bought it now sounds like valves are ticking I use 5w-30 halvoline do you think it might have had 10w-30? I had the 90000 mile service done already! Everything was ok! I'm thinking I need thicker weight?
Old 06-03-08, 07:34 PM
shaned1320
shaned1320's Avatar
i switched to 10-30 mobil 1 synthetic at 105,000 and a can of restore you should switch to synthetic.
Old 06-04-08, 04:12 PM
thadword
thadword's Avatar
I use kendall synthetic 10w-30 (dealership recommended). Anyhow, using synthetic is important.
Old 06-05-08, 08:11 AM
Bill Dowd
Bill Dowd's Avatar
The valve ticking is normal on the 90 to 94 lexus my got so bad I had to have the dealer ajust my valves which did quiet them down but it cost $885.00 it takes 7-9 hours to do the job. They also found a huge build up of carbon in my air intake and cleaned it out and the car now runs like a rocket. I have been using mobil one synthetic oil since 1985 in toyota's and have gotten 429,000 miles out of the engine and transmission power steering and rear end all using synthetic fluids the damn stuff seems to work. I now have 205k on my 91 lexus using all synthetic fluids and so far everything working perfect.
Old 07-22-08, 09:30 AM
ryanSC300lover
ryanSC300lover's Avatar
Do you guys recommend 5w30 or 10w30 on this car?
Old 07-22-08, 10:19 AM
ThaFuzz
ThaFuzz's Avatar
I just changed my oil, running 5-30 Royal Purple, no abnormal sounds.
But my car only has 66,000 miles.
Old 07-22-08, 10:21 AM
ryanSC300lover
Thanks. I will be running non syn, as I run syn in my other cars, but I am an original owner on those.
This LS has 117K miles, 95 model. Been running 10w30 previously.
Old 07-22-08, 10:32 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
spec is 5w-30
i run mobil1
Old 07-22-08, 10:34 AM
ryanSC300lover
Originally Posted by PureDrifter
spec is 5w-30
i run mobil1
Thanks, will pick up some 5w30 then. All my parts came in the mail today, so starting the big job of WP/belt/pulley/oil change/brake pads/hood struts
Old 07-22-08, 10:36 AM
LiCelsior
Retired
LiCelsior's Avatar
using Mobil 1's new Advance Fuel Economy 0w30 oil
Old 07-22-08, 12:52 PM
omarg
omarg's Avatar
me too. I'm gonna switch back to a heavier oil next time.my engine is a bit louder(stronger but safe ticking) than i remember on the thicker synth. i saw no increase in mileage.
Old 07-22-08, 02:46 PM
Lexkost
Lexkost's Avatar
spec is 5w-30
i run mobil1
10w-30 is also spec.........Remember we are in SoCal.....Heat.
Old 07-22-08, 03:54 PM
PureDrifter
BahHumBug
true...i use 5w because i occasionally take my car to big bear....
yes...its as useful as a snow plow
Old 07-22-08, 03:56 PM
ryanSC300lover
So 10w30 for socal and 5w30 for rest of the country?
I am trying to plan before my 2500 mile trip next weekend. I will be going through the southwest up to the midwest
Old 07-22-08, 05:24 PM
Bradster
Bradster's Avatar
10W30 Amsoil for many years now on a 90 with 240K miles..purrs like a kitten.
Quick Reply: Oil Viscosity?
