90 ls400 a/c not working
Old 06-02-08, 03:15 PM
martymar33
martymar33's Avatar
Default 90 ls400 a/c not working
hi guys, i have a 90 ls400...the other day i turned the air on and nothing but hot air, i raised the hood, compressor is not running and front electric fans are not running either. i checked both fuse boxes but can't find one labeled a/c.....thanks in advance
marty
Old 06-04-08, 04:43 PM
martymar33
martymar33's Avatar
anybody?????
Old 06-04-08, 05:46 PM
SH212
Dances with goats
SH212's Avatar
lol puredrifter where u at.. i know u can take this 1
Old 06-04-08, 08:24 PM
celsior 7
celsior 7's Avatar
it may be a blown fuse or most likely its a blown relay try taking out one of the relays in the box under the driver side head light while the ac is running and see if the ac compressor and radiator fans turn on.
Old 06-04-08, 08:34 PM
usermel
usermel's Avatar
Smile Could the Problem Be?????
Could the problem be the freon(Dont know if I spelled freon right). I was driving today in 90 degree weather and was thinking I may need to have my AC in my 2001 LS430 checked so, seeing your post just made me say I need to check on that. I say ask the dealer or a professional or maybe someone whose dealt with your issue who's a fellow member hopefully can help.
I tend to ask a pro, not to say asking your club members cant help at times but, a Lexus tech surely can tell you the problem or a qualified certified mechanic. Hope its not a costly issue for you bro!
L.G.N.M
Old 06-04-08, 10:19 PM
nawls400
nawls400's Avatar
My 91 is doing the same thing...except my fans are engaging...I was told by a mechanic that sometimes the compressor will not turn on if the freon is low...I haven't tried it yet...somone slashed my tires and i have a speeding ticket to pay still so money is really really tight right now.
Old 06-05-08, 10:48 AM
jdmacken
jdmacken's Avatar
Cool
When my 1990 LS400 Ac went out the compressor would not engage also. It will not when the freon is low. I took mine to several shops and they could not find the leak. I eventually found it. It was the evaporator core that is in/under the dash next to the heat/ac fan. I ended up switching my r12 freon to 134a and in hindsight I wish I would of not switched the freon type. r12 is much colder. Yes this fix will cost you some money but it is fixable. My suggestion is to take it to a mechanic you trust that works on AC. Have them recharge with r12 with a dye so that maybe you can see where the leak is which might be an easy fix first.
Old 05-05-10, 08:19 AM
willhickey
willhickey's Avatar
i have the same problem as this..........., it worked fine and then it stopped working so just disconnect the relay? try that first? thanks for the help and any other suggestions are widely appreciated
dustyshiv
05-28-16 05:33 PM
divineVIP
18
06-14-13 11:38 PM
bisessar10
10-26-11 05:25 PM
Dee_seal
Performance & Maintenance
05-11-05 12:21 PM
Woogie
Maintenance
07-30-04 12:53 AM
Quick Reply: 90 ls400 a/c not working
