Steering Issues
Steering Issues
I put a new set of wheels on my LS 18x8.5 front and 18x9.5 rear and not my steering wheel is now cocked to the left when driving straight ahead. If I let go of the steering wheel while driving, the car will go to the right (steering wheel will go to it's normal straight position). I got an alignment and everything is as close to perfect as possible. I did not lower the car at all. Could my front tires be causing my problems if they are not square (bought them used) or something else?
I took it back to Just Tires and they supposedly corrected the steering angle after I told them what it was doing. The guy told me he adjusted it as straight as it could be. He also said when he was backing it off the machine, he noticed it was trying to go left and right. That's when he said most likely it's a tire issue, but again before putting the new wheels on the steering was top dead center.
it's probably a tire. very often a tire will cause a pull due to the alignment of hte belts that make up the tire carcass. switch the front wheels/tires to the opposite side and see what it does.
also, with wider low profile tires, they will follow the road much mroe than standard grandpa tires. maybe that's what's happening. have you driven on different streets and the freeway since you got the wheels on?
Sorry if I am misunderstanding but did you get an alignment with the "new" tires and wheels on the car? Definitely part of the alignment process is straigtening the wheel. Obviously you checked that tires were inflated properly right? If the car is pulling to one side ask your shop for a print out. Mine gives a color copy showing caster, camber, toe, etc.
Hey guys...found out the issue...bought used tires, and apparently the front tires are no good. Thanks for all the responses...guess I will be getting new tires!!
Yeah i got a copy and everything checked out...that's why I couldn't understand the issue. both tires slope towards the left and are directional
newpuy
05-11-10 08:00 AM
