Looking for a regulated 12v
Old 05-08-08, 07:03 AM
black_LS
black_LS's Avatar
Default Looking for a regulated 12v
98 LS
I need to find a regulated 12v in the glovebox area to power my dvd-rom and usb hub (carpc install). Would I be able to tap into the ACC going to the CD changer?
Need to figure this out ASAP.
Old 05-08-08, 08:53 AM
Kansas
Kansas's Avatar
Although I tapped into the wire to the accessory plug in the center console when I installed my GPS, I have since come to the conclusion that the easiest way to power just about any device is to plug a piggyback fuse adapter into the under dash fuse box. It should be fairly easy to run a wire from the underdash fuse box to the glove compartment area. I ran wires all over the place behind both sides of the dash when I installed my phone kit although I found that popping the radio out made it easier to run wires.
Old 05-08-08, 09:12 AM
black_LS
black_LS's Avatar
So there is no problem with powering devices off the ACC line? This would work best for me as I have some stuff in the trunk that needs regulated power and I'm already running the ACC back there to turn on my amps.
needslipo
12-21-16 01:48 PM
914lps
13
06-26-13 11:35 AM
Tact
ES - 5th Gen (2007-2012)
16
01-12-13 12:56 PM
got56ry
09-11-08 02:06 PM
blknfury
Performance & Maintenance
13
11-29-07 11:00 AM
Quick Reply: Looking for a regulated 12v
