Brake fluid brand?
Old 04-18-08, 01:46 PM
Ls4hundred
Ls4hundred's Avatar
Default Brake fluid brand?
Is there any particular brand you guys recommend for brake fluid?
Old 04-18-08, 06:14 PM
RA40
Super Moderator
RA40's Avatar
I've been using Valvoline synthetic.
Old 04-19-08, 02:02 PM
Ls4hundred
Ls4hundred's Avatar
Ok, thanks for replying.
Old 04-19-08, 07:09 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
i thought i just answered this
Ate Super Blue
Old 04-19-08, 07:39 PM
Ls4hundred
Ls4hundred's Avatar
This is the first time I have asked this, I have asked other brake related question s lately though.
Old 04-19-08, 09:00 PM
dragonhvu
dragonhvu's Avatar
Originally Posted by PureDrifter
Ate Super Blue
this stuff works great
Old 04-20-08, 07:47 AM
Lexmex
Super Moderator
Lexmex's Avatar
Agreed, ATE is excellent.
Old 04-20-08, 10:46 AM
leximan
leximan's Avatar
yeah...go with it
Old 04-20-08, 03:27 PM
LexFather
Guest
Posts: n/a
Valvoline Dot 3/4 is good
ATE is great, you can get it at the Tirerack. It comes in blue and gold, so you can tell when all the brake fluid is drained. Its Dot 4 and used by many people that track their cars.
Old 04-20-08, 03:31 PM
DIY LS400
DIY LS400's Avatar
I used Castrol GT LMA fluid when I flushed out and bled my brakes, which was the best at the store I went to. Funny thing though, the bottles I bought were the original design and recently I went to the store and noticed that they change the design and it now says that it's synthetic. I wonder if it was always synthetic or if they just changed the formula.
Old 04-20-08, 07:23 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,079 Likes on 2,472 Posts
Castrol SRF is the best for a track car unless you've already installed speedbleeders and don't mind bleeding your brakes before every track day. For my street cars and bikes I use Valvoline Synthetic. It's cheap, has a reasonable dry/wet boiling point, and I've never had an issue with it in the last 10 years I've used it.
Old 05-04-08, 10:35 PM
1genls400
1genls400's Avatar
Ate Super Blue
can i add this to my present brake fluid in the car? where can i get this at?
Old 05-05-08, 06:32 AM
Lexmex
Super Moderator
Lexmex's Avatar
The LMA is also quite good and the SRF is amazing, though I used it once in my RX300 and had some contamination issues, but it definitely is the best brake fluid on the planet, but it costs $$$.
You can add the ATE to your present fluid (I am assuming you are a bit low), but the best is to go get the fluid flushed and move to the ATE.
Many auto specialty shops sell ATE. I used to get ATE at BMW. Tire Rack one of our CL sponsors, sells it, http://www.tirerack.com/brakes/ate/a...blue_fluid.jsp
Old 05-05-08, 05:47 PM
DIY LS400
DIY LS400's Avatar
http://www.pegasusautoracing.com/pro...p?Product=3343
I don't think any of us need to get $80 brake fluid. That is just overkill for a commuter car.
Old 05-05-08, 08:03 PM
RA40
Super Moderator
RA40's Avatar
I flush mine ~15K miles. Considering the level of braking my typical commute involves, it's far from high heat conditions. Unless there is specific need, most the common DOT approved fluids will function fine. Save the $$ for some other goody.
RageRacerM
Suspension and Brakes
11-20-18 08:05 AM
babyduke
ES - 5th Gen (2007-2012)
11-25-14 05:23 AM
Loyalone72
12-24-13 10:55 AM
TexasGS
04-27-06 08:23 AM
ifilrx
10-31-05 08:01 AM
Quick Reply: Brake fluid brand?
