Test fit: 19x10 -7 AME Shallen LX
Old 04-17-08, 01:04 AM
NJ240sxMan
NJ240sxMan's Avatar
Default Test fit: 19x10 -7 AME Shallen LX
Here's current progress on my fender pulling trying to fit these beasts.
19x10 -7 AME Shallen LX 235/35/19 Falken FK452
I got two friends to sit on the rear for the pictures
I'm hoping that it'll tuck it completely with just camber from this point on. Let me know what you think. This is my first experience using my MAX fender roller.
Old 04-17-08, 01:14 AM
anotherLS
anotherLS's Avatar
this is the reason i cut fenders than roll! looks like u need a pull
Old 04-17-08, 01:18 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
still need a decent bit more of a pull, unless you run super stiff on ur next susp setup (which i wont reveal here ) it WILL hit on bumps.
Old 04-17-08, 05:20 AM
LiCelsior
Retired
LiCelsior's Avatar
lol copycat!! jk, looks great dude. are u going to carlisle with the car if its ready?
Old 04-17-08, 06:57 AM
19psi
19psi's Avatar
man if you can get those to work it will truly be sick. you need a lot more pull for sure and max the camber. the camber doens't do too much though, the adjustment is pretty small. you'd really have to get it low as well.
Old 04-17-08, 08:14 AM
NJ240sxMan
NJ240sxMan's Avatar
I am going to end up getting different tires for the rear.
Should I go with 225/35/19 Falken ST-115's or 225/35/19 Federal SS595's?
I'm kinda leaning towards ST-115's since they run narrower.
Old 04-17-08, 09:37 AM
KilaWombat
KilaWombat's Avatar
love those rims, cant wait to see you get it all fitted. gl
Old 04-17-08, 10:32 AM
Brandicus
Brandicus's Avatar
lovin it. Id recommend the feds just because ive heard some nasty things about falkens and stretch and im super happy with the stretch on my feds.
keep us updated!
edit: just for reference heres 245/35 on my 10.5
Old 04-17-08, 01:32 PM
steveski
steveski's Avatar
Very tight setup - the tire is still touching the fender - definitley looks like some pulling is in order - looks great though
Old 04-17-08, 01:44 PM
NJ240sxMan
NJ240sxMan's Avatar
I actually remembered I have 225/35/19 General Exclaim UHP's on my 19x9 SSR's back home. So I'm considering putting them on the rears. I'm gonna try pulling more. I finished the driver side fender today (minus pulling even more), and got it a bit further than the passenger side and even cleaner.
One of the guys on VSC actually suggested to try pulling even further so I'm gonna go at it on Saturday and try to pull it even more. I am confident I can pull it more so we'll see what happens. I'll likely get to finish it on Saturday.
Old 04-17-08, 02:04 PM
genetic
genetic's Avatar
run those 225s so you dont have to pull them that much
Old 04-17-08, 02:11 PM
VNN326
VNN326's Avatar
run more camber
Old 04-17-08, 03:36 PM
NJ240sxMan
NJ240sxMan's Avatar
Update:
Old 04-17-08, 06:36 PM
genetic
genetic's Avatar
id probably go with falkens because federals run wide.
any progress with the fronts? they probably dont need much work but anywayas its gonna look awesome. good luck!
Old 04-17-08, 07:24 PM
PureDrifter
BahHumBug
first off, falken ST115s dont stretch well at all iirc, id go with the federals or like i did, Generals
and regardless you STILL need to either pull a bit more or camber the hell out of it. almost there!
Quick Reply: Test fit: 19x10 -7 AME Shallen LX
