Since youve owned your LS...
Old 04-11-08, 10:54 PM
1995LS400
1995LS400's Avatar
Default Since youve owned your LS...
what is the first thing that has broken down or had to be replaced? Being the most "dependable" car in the world doesnt mean that some wear and tear items might go bad, (i.e. tires, pulleys, belts, etc.).
The only thing that has let me down in the 8 months of owning this car is the battery. It was a genuine Lexus one, but who knows how long it was in the car. The year and month little dots were never marked at the dealer.
Old 04-11-08, 10:58 PM
TJW98LS
TJW98LS's Avatar
A battery and standard maintanance...
tires, brakes, oil, and gas... thats all theses cars need to run
Old 04-11-08, 11:26 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
trans mount, random filters, oil, trans fluid, trans solenoid+harness (somewhat common on 98-00 LS4 and GS4), battery (replaced OEM Lexus, as in 8 years old...), coolant hoses (ends corroded since previous owner didnt use toyota fluid....), and front pads+rotors. need to replace some other stuff but it isnt wear+tear.
Old 04-12-08, 06:11 AM
timer00
timer00's Avatar
Battery, Hood Struts (common on all LS), and V belt
Old 04-12-08, 09:49 AM
Chilkoot
Chilkoot's Avatar
Things I've replaced:
by choice for peace of mind/preventative maintenance: timing belt (long past due), spark plug wires (longer past due), spark plugs(longest overdue), distributor caps/rotors, fuel filter, air filter, rear pads (done w/ fronts just because), PCV valve (still rattled, but like 3x the weight of the replacement, definitely the original)
because of minor symptoms: water pump (minor coolant leak), idler pulleys (noisy idle), coolant reservoir (minor coolant leak), heater control valve (not replaced yet, sitting in my trunk, but a very minor coolant leak from it), motor mounts (serious vibration at idle, my fault for trying starter trick to bust crank pulley loose)
because of major symptoms:
front rotors and pads (there were no pads left), driver's window motor (motor failure), wheel locks (the key stripped while I was changing a flat ), hood struts, battery
and i also had a rear main seal leak that came with the car, it went away after the first oil change when I switched to synthetic (before I even drove it home).
This is all for the period between 129-133k miles that I have owned the car, and most everything i replaced was original (down to the plugs and wires). through service records I've discovered the o2 sensors were replaced in '01 and the pump/rack/pinion were replaced in '04.
I knew about all of these issues before I got the car, so it was priced accordingly ($1,500), took about 2k in parts to fix for $4,500 of indie quoted work (the quote included dash panel $1100, coolant tank $400 and window motor $700, so that's why it seems so high).
Old 04-12-08, 12:17 PM
tbilisi79
tbilisi79's Avatar
Nothing.
THe only thing that broke once were the Horns, they just died, dont know why.
I am not countring Timing belt, motor mounts and trannt mount, brakes, those are wear and tear things, like tires.
Old 04-12-08, 12:50 PM
Atl
Atl's Avatar
My 99 LS total so far:
1) Timing belt change, plus all the extra stuff they change during this service.
2) Rear main seal blew, my God was that expensive!
3) "O" ring dipstick gasket thing.
3) One engine valve gasket.
4) Turned the rotors.
5) New tires, Go to Costco or Sam's Club for best prices.
6) Was going to get hood struts until they told me how much, they said $400.00 !!! With a straight face, incredible. I'll prop it up with a stick.
7) New windshield, not cars fault, actually my dad was driving when it got hit.
$1500.00 for a Lexus OEM windshield, but Insurance paid for all of it except
$250.00, my deductable.
8) Tranny mount.
Would a Ferrari be cheaper to maintain??? I wonder
David
Old 04-12-08, 01:39 PM
PureDrifter
BahHumBug
8) Tranny mount.
David
hah, keep dreaming, even a 5k mi. service (and you do have to go to EVERY 5k mi. service...) costs upwards of $4000.
(for a 360...)
Old 04-12-08, 02:01 PM
Atl
Atl's Avatar
(for a 360...)
Well... How much for Ferrari hood, or should I say, boot struts ????
Old 04-12-08, 02:20 PM
PureDrifter
BahHumBug
no idea, but the 360's water pump ALONE is about a grand
http://cgi.ebay.com/ebaymotors/NEW-O...spagenameZWD1V
Old 04-12-08, 02:43 PM
sonyman
sonyman's Avatar
The starter.
Old 04-12-08, 06:50 PM
Bennay
Bennay's Avatar
rear struts, tires, front left turn signal.
i want to do plugs and wires but i think their fine for another 25000km's or so, my 93' runs like a dime with 236k kms on it.
Old 04-12-08, 07:53 PM
avalon42
avalon42's Avatar
Yea, that just means that Ferraris are built as DIYs kind of cars...
...oh wait.
Old 04-12-08, 08:17 PM
GKLCPA
GKLCPA's Avatar
I've done nothing other than basic maintenance (tires, oil changes and etc). I've got my first timing belt change coming up next week
Old 04-13-08, 12:53 PM
heyhowyado
heyhowyado's Avatar
other than regular maintenance, the only thing i've had replaced were the starter contacts.
Quick Reply: Since youve owned your LS...
