I have two LS400's both are 1 owner cars, need help with one
My 1990 is acting up on me. I have a check engine light and also my tachometer does not work. Has anyone have a tachometer problem where it does not work?? My car also idle's little high, its something I cant see cause the tach dont work but I can feel the engine running bit more high idle. Im getting horrible gas mileage, LIke 200 miles a tank!!!!!!!!!! NEED HELP bad!!, IM thinking the check engine might be o2 sensor, if someone can help me please respond.
Retired
www.lexls.com has most of your answers. ur tach problem is most likely a bad cap, theres a huge sticky on that labeled "1000 dollar fix on instrument cluster?" at the top of the LS400 forum. go to the website to run the codes for your car and come back, SEARCH for the codes and if all fails then post in here on updates.
thank you for the response
Ill check out the site, Ill have to do a diagnostic to see whats the problem but the way its drinking the fuel , Im going broke, Have to get it fixed
chris2387
03-08-15 10:05 AM
