High or Low Beam?
Old 04-04-08, 09:55 PM
en11871
en11871's Avatar
Post High or Low Beam?
Hi,
I have one very silly question. Are low beam and high beam bulbs different in wattage? If so what is the difference? Can I actually use the same type of bulb for both, providing they are the respectively correct part numbers (9003, etc)? PLMK. Thanks.
1996LS
Old 04-04-08, 10:17 PM
Neofate
Neofate's Avatar
--Edit -- First and second gen are not the same --
Old 04-04-08, 11:11 PM
phobs
phobs's Avatar
On the 1996 LS, the low beams uses 9003/H4 bulbs while high beams use 9005 bulbs. I am not so sure about the wattage.
Old 04-04-08, 11:18 PM
en11871
en11871's Avatar
Post high or low beam
Originally Posted by Neofate
I assume it is the same in the Second gen -- Your high beam and low beams are the same bulb. So, yes, the same part number (900x) is going to be it. IE: I changed out my headlight 'Bulb' on each side with the High intensity Sylvania's.. (Highest Intensity you can get for stock wattage ) -- And its one bulb per side.
Inside the bulb are two filaments, one for low beam, one for high.
If that makes sense.
Second gen could be separate.. but I wouldn't imagine so.
Neo,
The low and high beam bulbs are separate. So can I use the same type of bulb in both locations? The low is 9003 and high is 9005. Just wondering if I can use the same type/style/wattage bulb in both locations.
Old 04-04-08, 11:32 PM
phobs
phobs's Avatar
The low beams are 9003 so you have to stick with 9003 bulbs. You cannot put the 9005 in the low beams, vice versa. If you are getting replacement or upgraded bulbs, stick with brand names such as Sylvania.
Old 04-05-08, 12:07 AM
en11871
en11871's Avatar
Hi,
Yes I will put 9003 and 9005 respectively, but just wondering if I can use the same type of bulb or do I need a more "powerful" ones for the high beam. I was thinking about getting the same bulb as my low beam in the high beam. PLMK.
Old 04-05-08, 12:44 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
9005 bulbs shouldnt be more than 65watt for the high beam.
Old 04-05-08, 12:45 AM
PK_Celsior
PK_Celsior's Avatar
it doesnt matter. the beam pattern of the low beam and the beam pattern of the high beam are totally different. thats why high beam and low beam look different.
Old 04-05-08, 12:51 AM
Neofate
Neofate's Avatar
Originally Posted by en11871
Hi,
** The High beam bulb is the same 'type' of bulb. It is going to look similar to your low beam. There isn't anything special you need to look for. Just get what is designated for your high beam.
IRANDY1948
04-06-16 01:50 PM
psp
Lighting
10-18-06 11:10 AM
DcBoone
IS - 1st Gen (2001-2005)
12
08-11-06 08:51 AM
Quick Reply: High or Low Beam?
