REAR taillights wont turn ON!!!(but they work when i brake??)
no fuse is blown, all the other lights work...they come on when i brake but they dont when i turn on my parking lights..bumper light and corners tron on but my rears dont????any ideas??? oo and this happened when i hooked it up to the trailer....any help guys???
thanks i'll do that..hope it works....i need the car to be perfect for friday(movin day)
Holy carp! I am having the EXACT same issue now. Fuses are good, and I can't seem to figure out why the two rear corner tail lights have no power but the trunk trail lights come on. The corners work for the brakes, just not the parking lamps.
I have checked the trailer wiring with a continuity tester to make sure that the connections are good (They are) and the turn signals and brake lights work. Seems that the green wire with orange tracer is just getting no juice.
Any suggestions?
Any suggestions?
http://www.lexls.com/tutorials/lighting/bulbout.html
this is a very good possibility. i am having a similar issue where my outers only work as clearance and my inners only work as brake. haven't been able to track it down though.
That trailer harness is def the problem. When I had it on The MDX, the left turn signal would stay on steady instead of flashing and so did the indicator on the dash. When I disconnected the harness problem was solved.
