99 LS400 Tilt Wheel problem
Old 03-02-08, 10:42 AM
luvmylexus
luvmylexus's Avatar
Unhappy 99 LS400 Tilt Wheel problem
The Tilt and Retract function on the steering column has ceased to work. I can extend and retract the coulumn manually with the column switch but the Tilt function does not work at all. There is no sound when I try to tilt the wheel with the switch. Anyone have any advise.
Thanks
Old 03-02-08, 11:28 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
motor is gone methinks, normally when theres an issue with the worm gears u get a grinding sound when u try to tilt it using the switch.
Old 03-02-08, 12:11 PM
Kansas
Kansas's Avatar
We will of course be easy on you since you are new -- but the search feature of this forum can often provide the detailed information you are looking for.
Here is a thread where I posted all the TSIBs regarding the tilt/telescope issues of the 1998-2000 LS400: https://www.clublexus.com/forums/sho...highlight=tilt
ansonng666
09-24-18 05:16 PM
tcordi
21
09-07-18 04:57 PM
JacketJet
08-31-17 06:04 AM
BobN54
01-29-12 05:01 PM
Lexs400
Maintenance
11-17-06 04:12 PM
Quick Reply: 99 LS400 Tilt Wheel problem
