knocking noise in rear end of my 94'ls?
Old 03-01-08, 11:19 PM
dedott21
dedott21's Avatar
Question knocking noise in rear end of my 94'ls?
i was driving on the highway when i started to hear a small knocking noise like its coming from the rear tires.i was driving the speed limit(65) until i heard the noise then as i got off the exit,the slower i went(40)it has gotten worse.i've pulled over into a shopping mall to check the tires to see if i have a bubble in the tires but after inspecting the tires,there was nothing,i got back in the car and continued to drive and the noise was there,again!once i've got it home in my parking space,i heard a loud clunk,again!i'm thinking its my bearings in the axle!can anyone give me advice?
Old 03-02-08, 12:45 AM
rominl
exclusive matchup
rominl's Avatar
welcome to CL. we have a forum dedicated for the LS400 forum. i have moved your thread there to get more exposure
Old 03-02-08, 12:57 AM
gdave
gdave's Avatar
north jersey lexus meet?
for next saturday?
Old 03-02-08, 08:52 AM
Och
Och's Avatar
Sound like your bearings are shot.
Old 03-02-08, 10:42 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
also could be the rear diff going, id swap the fluid out, its cheap and easy and couldnt hurt.
Old 03-02-08, 12:52 PM
richonenz
richonenz's Avatar
There's a radius type arm that comes off the bottom of the hub and goes on an angle to the chassis , it's quite likely that the bush in the hub is completely stuffed , this allows the hub to move backwards and forwards and it will clunk , jack the wheel off the ground and grab the tyre and try and move the wheel backwards and forwards violently...then you will know !!
Old 03-02-08, 01:06 PM
PureDrifter
BahHumBug
the rear carrier arm+strut bar bushings, knew i forgot something
Old 03-14-08, 07:31 PM
dedott21
dedott21's Avatar
i will have both the rear differential and the rear carrier arm/strut bar bushing checked out,buy the way,how much and where can i get the bushings from besides going to the dealership (lexus) to get them?
Old 03-14-08, 07:33 PM
dedott21
dedott21's Avatar
the wheel bearings? are they easy to put on?and how much are they or you can direct me to a web site to find them?
Old 03-14-08, 07:35 PM
Neofate
Neofate's Avatar
Sounds like a fairly obvious problem to someone who knows cars. I would personally drive it to any ASE master mechanic around town and ask them if they would drive your car down the road and back and tell you what it is. Sort of indicate that you would want them to do the repairs.
After they tell you what it is,.. thank them, and get a business card to come 'back' for repairs because you have to be at X place,.. or need Y money
It is 5 minutes of their time and will save you alot of time and potentially replacing parts you don't need to.
Old 03-14-08, 07:38 PM
Neofate
Neofate's Avatar
Oh and if it is the bearings.. yes they are relatively easy to change out.. No crawling under the car or reaching into tight spaces.. Just jacking the car up and pulling wheel and so on..
Old 03-14-08, 08:28 PM
PureDrifter
BahHumBug
simple, but shops will get you by charging labor for like 3-6 hours depending how compentant/honest they are...
Old 03-14-08, 08:32 PM
dedott21
dedott21's Avatar
i appreciate the advice.thanks!do you know any parts store online where i can find the bearings at?
Old 03-14-08, 08:34 PM
dedott21
dedott21's Avatar
thanks ,thats my biggest worry!!!is there a post where i can do it myself with step by step instructions?
Old 03-14-08, 11:08 PM
Neofate
Neofate's Avatar
Not that I can find that I think you are wanting.. (pictures and such) --
Though this *is* a job where someone could give you a quick run down without pictures of the basic procedure on this car and you wouldn't run into any trouble doing it. It is straight forward.
I won't attempt it, because I haven't done the bearings on this car -- Last car I changed was a Nissan 300ZX.. many years ago. So I'll leave it to someone more intimate with the bearings of the LS
Quick Reply: knocking noise in rear end of my 94'ls?
