98-00 Fog Light Removal....
Old 02-24-08, 06:49 PM
Jasbmo
Jasbmo's Avatar
Default 98-00 Fog Light Removal....
I'm trying to remove my foglights for my '98 LS as there is some strange residue on the plastic that I'm trying to grind off....how do you remove the entire fog light housing?
Thanks!!
Old 02-24-08, 06:59 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
theres a screw u take out, then the outer pieces come off, followed by the inners.
Old 02-24-08, 07:32 PM
Jasbmo
Jasbmo's Avatar
Once you remove that screw (close to the front tires), do you just yank the plastic pieces out? Does the top come out firs then the bottom? Side to side??
Old 02-24-08, 10:39 PM
DIY LS400
DIY LS400's Avatar
Take out the visible screw on the side, then stick a flathead, cover with a paper towel or something soft, and pry the side piece out. Then you'll see the other screw holding the actual fog light in.
Old 02-24-08, 10:48 PM
PureDrifter
BahHumBug
i prefer a 1" flexible plastic putty knife, it leaves no mars on the brittle plastic
Old 02-25-08, 12:15 AM
DIY LS400
DIY LS400's Avatar
^ that's a good idea, I already scratched one of my fogs with a rogue flat head.
Old 02-25-08, 05:17 AM
greenvy2k
greenvy2k's Avatar
i believe that the screw on the fasia of the fog light dosen't do much. it does not hold the fog light in.
Old 02-25-08, 10:25 AM
PureDrifter
BahHumBug
it does. but it does so IN ADDITION to the plastic clips.
not a good idea to not have the screws in there, i wouldnt trust my $$y fogs to just a plastic clip.
Sheadninja
12-09-15 08:27 AM
ceegeeaye
GS - 1st Gen (1993-1997)
02-25-12 03:34 PM
globaltrav
Lighting
11-04-10 05:00 PM
Marc-P
SC- 1st Gen (1992-2000)
02-05-07 09:08 PM
ToyLexmods
11-02-01 03:31 PM
Quick Reply: 98-00 Fog Light Removal....
