Ticking sound from engine is it normal?
#31
Mine ticks right now and it gets louder as you get on it.The guy I bought it from said it was probably stuck lifters from sitting so long.I knew it wasn't rod knock because it just didn't have the same sound.Once I had my friend look at it he determined its just the EGR tube thats cracked.
Colin
#32
I hear the tick tick only when I am at a drive thru where the wall amplifies the noise and I have my window down. Mine is a '92. Probably normal. Is the statement that if the injectors are clean they make no noise true? My car runs very well and I get 18 MPG in city and 27 on the highway
#33
"clean injectors will tick, dirty injectors are silent"
Sounds logical to me. So your injectors are probably clean.
#36
A little disapointed
I have to say that I am a little disapointed that I would have to go through and adjust the valves after only 188000 miles. I have done this procedure when building a 7MGTE / 7MGE engines or after having the valves ground but never due to wear. Even all of those Corollas running around out there with the same bucket/shim set up are quieter and with more miles than my LS400.
Sorry, just had to vent.
Can anyone for certain tell me why? Are the valve seats retreating into the head? If the valves were wearing then I would think you would have more instances of burned valves. If the cam lobes/shims were wearing then I would think you would have more failures due to flat cams.
#38
All things considered
For having 188k miles it really has been a great car. The key I found is to address the problem as soon as it happens instead of waiting until disaster strikes.
#39
I remember in other cars of mine that the electrical system would tick. Was it the distributor or spark plugs? Can't remember.
I have a similar question. When I push the accelerator pedal and then let go, as it revs downwards theres a large creak/ticking once it hits low revs. This happens every time I push the pedal and let go.
#40
Let's revisit this thread.
So if rhetoric is that this is normal; did these engines sound like this when they were released from factory? I'm sure being that it's 20 years later there is a difference but how to get it as close to factory as possible? I took note of the pictures and diagram posted earlier in the thread so as to give it a shot tomorrow but is it definitive?
#42
I can hear my injectors at the drive through or similar. When the sound is bouncing off the wall and the window is down. I think many people are confusing injector ticking vs valve slap. It's a waste of money to pay for a valve adjustment until you starting hearing real valve noise. Need to listen for it at the cover. Plus, the knock sensor code would be activated.
http://www.northerntool.com/shop/too...FZNj7AodvmoAIg
#43
Now that sound would worry me. My 92 has some very minor tick most what i hear is a bearing on a pulley sounding off once and awhile. But even that is very minor don't even hear it with hood down.
#44
the sound on that video is no valve tick at all, that is more along the lines of a rod knocking, or if it is a valve, it is a valve hitting a piston!
whoever owns the car in that video needs to be checking out the latest auto-trader issue, or else ebay, that car won't be running in 6 months
