Help with Fog light rewire
Old 02-12-08, 05:43 PM
jcrome04
jcrome04's Avatar
Exclamation Help with Fog light rewire
CRAP! So I have my dash taken completely apart and I need to know what is what on the relay.
The labels are 5, 3, 1, 2.
I need to know:
+ Trigger
- Trigger
+ Source
+Output
(according to DIY)
http://www.scionlife.com/forums/arch...xus-ls400.html
I need any advice quick so I can put my car back together! lol.
Old 02-12-08, 09:48 PM
trukn1
NELOC Mod
trukn1's Avatar
Bruh, you have just committed the one mortal sin that anyone in CL can commit to,, and I should turn the hound loose on you, LOL!!! PD, don't worry man,,, I got this one. In the words of the IMMORTAL PD,,,SEARCH!!!! LOL!!!
This has been covered before, and in fact it was the afore mentioned person from above who provided the info. I am gonna give you 1 free pass today,,
https://www.clublexus.com/forums/sho...9&postcount=10
This should work for your car.
Full thread is here,,
https://www.clublexus.com/forums/sho...t=foglight+mod
Old 02-12-08, 09:56 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
you need this thread. https://www.clublexus.com/forums/sho...d.php?t=144434
then this www.google.com
from which you would have found this. http://www.ado13.com/techs/relay.htm
either way, next time try to read THEN attempt a mod
for your relay, based solely on the useful picture on it:
1-2 is the coil, so when u apply +12v to these two the 3-5 pins will have continuity.
so for your application, the ORIGINAL +12v from the headlight switch will go into say pin 1, then the ground from the foglight switch will go into pin 2. Then to make it work you just have to wire the constant +12V from the fog light fuse to pin 3 and the output from the relay to the foglights on pin 5.
havent u used relays before? its pretty basic stuff this...
my main question is why are u using another relay? the easiest way to do it is to just make a tiny harness to extend the original foglight relay out a couple inches so that instead of the headlight switched +12v u can use any +12v to turn them on...
Old 02-12-08, 11:24 PM
jcrome04
jcrome04's Avatar
Sorry I swear I searched! I was probably just too flustered. hahaha
I really appreciate this though! I did make 4 new wires to extend the harness. i'm just a real visual person so pictures for me is WAY easier than a list of steps.
i just didn't know which was the source/ground/trigger, whatnot. . . I put everything back together though, a lot easier than I thought it would be.
and lastly, should I just put it in with a fuse?? or splice it in with another wire?
Old 02-13-08, 08:53 PM
skperformance
skperformance's Avatar
Use a fuse , i added a add a mini fuse which attaches to an existing fuse without any wireing modifications.
alexdao12
06-20-14 02:30 AM
IS300kidd
IS - 1st Gen (2001-2005)
03-31-13 05:01 PM
dumped99gs
08-28-12 02:25 AM
aasim305
02-24-10 07:27 PM
4ntvings
Lighting
03-06-07 06:41 PM
Quick Reply: Help with Fog light rewire
