lexus will not start
Old 01-29-08, 10:57 PM
celsior 7
celsior 7's Avatar
Default lexus will not start
alright so i have an idiot for a friend who has an ls400 like mine and he was doing some work on the car while it was running and some how got a rag stuck between the camgear and the timing belt i removed the rag for him and afterword the car would not start. he says that when the rag got stuck the engine shut off like 4 seconds later. so i figured the timing was off and i was right i re adjusted the timing. yet still the car does not start. does anyone have any ideas on how to deal with this? any help will be greatly appreciated.
Old 01-30-08, 12:46 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
look over everything, sounds like something killing spark/air/fuel, the motor is most likely NOT damaged as 1st gens arent interference engines.
Old 01-30-08, 07:12 AM
celsior 7
celsior 7's Avatar
yeah i kind of figured that hmmm. see i think im getting combustion in the chamber but maybe not enogh spark to keep it going. tahnks for the info man.
Old 01-30-08, 11:14 AM
BIGBADDAD
BIGBADDAD's Avatar
Does it sound like it wants to start???
Are you sure that when you did the timing, that every thing was set (start from the begining), or did you just re-set the side that ate the rag? My intention is not to be-little you, I just need to know what has been done. What was your friend working on?
Start by checking basics "fuel, spark, compression". Please let us know a little more, and I am sure one of these guy's will have the answer.
Take care and sorry to here about your idiot friend...we all have them, and we wouldnt be the same with-out them
Mark
Old 01-30-08, 11:18 AM
lxtauto
lxtauto's Avatar
check the cam sensors and crank sensor for cracks or wires cut
Old 01-30-08, 11:54 AM
19psi
19psi's Avatar
^ what he said. i bet the rrag got dragged though some of the engine harness and broke a cam or crank sensor plug off.
and did you reset the t belt completely or ?
Old 02-03-08, 08:14 AM
celsior 7
celsior 7's Avatar
sorry it took me a while to get back. yes the car sound like it wants to start and and yes i set the timing belt fully it is all lined up. i can smeel gas coming from the rear exhausts when i crank teh motor and teh rpm needle jumps a bit but it doesnt keep going.
Old 02-03-08, 08:15 AM
celsior 7
celsior 7's Avatar
also he was working on a power steering problem he had a craked hose or something
pentzj
IS - 1st Gen (2001-2005)
11-11-18 07:02 AM
Biddles
Performance & Maintenance
62
11-21-17 06:15 PM
PatBrown
RX - 1st Gen (1999-2003)
06-13-13 07:47 PM
Dtwillis5
16
05-11-11 11:10 AM
Och
12-26-07 05:33 PM
Quick Reply: lexus will not start
