Instrument Cluster Issues
Okay - Just got a '93 Lexus LS400 thru a trade for an '87 El Camino a few weeks ago.
And now I need some advice.
I come to find out that the instrument cluster is bad. Very much the same as I have read on this forum. The backlight is out, the tach and speedo needles are not lite and are broken off. At first, some of the lights would come on when cold morning or night, but then would flicker for a bit and then dissappear as the car warmed up or I drove a bit. The gas gauge seemed to have a twitch at times, and jump above the (E) but would eventually remain below the (E).
I searched this forum and read that there were a few who could repair my cluster and one of which (Lexustech) was only 20 minutes from my house. So I brought the unit to him and he took a look at it and confirmed what I had found. The bad news was, that he could not repair it as he said the gas gauge was severly damaged and the needles broken. He felt I should buy a rebuilt unit that he had.
Well I took my old unit home ( unrpaired ) and re-installed it. Guess what ? The gas gauge moved above the (E) rested at 3/4 full and then eventually moved to Full after a while. Yes I have full tank of gas. The same lack of lighting remained but they have not yet flickered. Could I have reset something when disconnecting the battery and unplugging/plugging the terminals of the cluster in ? Can this cluster be repaired at a reasonable price and who can do this ? And what is a reasonable price.
I have read about Jim Walker, Mr Wizard, LexusTech and Mikadotech.
Any Thoughts ?????
Any Thoughts ?????
Retired
read the sticky up there? my post that helped a few people.
C142 is the fuel gauge cap, didnt replace it then when i posted but have now and it works good.
page 6 has alot of good info, and to fix the fuel gauge problem u need to change the capacitor on the main board labeled "C142" and i'm still trying to find out which capacitor is for the fuel gauge. changed C201, C205, and changed the C212 and my lights work, its just the fuel gauge and engine temp gauge isnt working.
