Clicking noise at the shifter...getting louder
Old 01-09-08, 02:11 PM
en11871
en11871's Avatar
Exclamation Clicking noise at the shifter...getting louder
Hello Guys,
When I step on the brake pedal when the car is in "PARK" there is a clicking sound at the shifter. That is normal, I believe, but recently the clicking sound has been louder. My mechanical suggested a "shift lock solenoid", but I'm not having any luck locating such part. Any help will be greatly appreciated. BTW, I'm in the process of changing my master cylinder AND power booster!!! Is "clicking getting louder" problem the result of the faulty master cylinder and/or power booster? Many thanks.
Old 01-09-08, 05:13 PM
skperformance
skperformance's Avatar
Lube the switch lock out for the shifter.
Old 01-09-08, 05:36 PM
qha_vn
qha_vn's Avatar
mine is clicking as well when I step on break, shift lock control switch fails intermittently, when it fails i have to use the shift lock override button
i think the clicking sound is produced when the control switch malfunction causing the solenoid to work continuously.
find no cure so far, still bear with it
Old 01-09-08, 05:49 PM
en11871
en11871's Avatar
Hi,
Thanks for your reply. So the actual part is called "switch lock"? Can that be replaced?
Old 01-09-08, 05:52 PM
en11871
en11871's Avatar
...but the clicking sound has always been there. I think that is normal, but recently the sound has been much louder. So say in the morning when I get in the car. I step on the brake, it makes a click at the shifter. That's normal right? It is just that click is louder now.
Old 01-09-08, 07:37 PM
skperformance
It is supposed to click but if it gets real loud or sticks it needs cleaning and lubing.
Old 01-09-08, 10:29 PM
en11871
en11871's Avatar
sk,
...so I'm assuming that part is located at the shifter?
tpeter
Performance & Maintenance
06-24-19 05:31 PM
capo64
09-17-14 06:26 PM
dr gtr
04-10-12 02:05 AM
JiBBeL
Suspension and Brakes
08-05-09 06:26 PM
en11871
01-22-08 07:08 PM
Quick Reply: Clicking noise at the shifter...getting louder
