94 LS400 Surges at more than half throttle...
Old 01-08-08, 10:49 AM
j stuff
j stuff's Avatar
Default 94 LS400 Surges at more than half throttle...
Hi guys
Just got a 94 LS 190k miles on it. Only issue thus far is that the car feels as if its surging if you step on the gas at more than half throttle. If you take it slow and drive it very lightly it wont do that.
Any ideas?
I read something while searching that said it could be spark plugs?
Old 01-08-08, 09:03 PM
j stuff
j stuff's Avatar
anyone?
Old 01-08-08, 10:00 PM
kens97sto
kens97sto's Avatar
Possibly the Throttle Position Sensor... I also have a 94 with 183k. But mine acts a little strange at 1/4 or less throttle... not surging.. but the power goes up and down a little.. It is just barely noticable. Changin the TPS is not that hard, and you could check it with a OHM Meter... Could also be an air leak somewhere... or also a fuel pressure problem... there are many possibilities.
Ken
Old 01-08-08, 10:42 PM
j stuff
j stuff's Avatar
Thanks ken
ill check the tps. I figured it may be due to an air leak and i noticed that the airbox and pretty much everything else attached to it is pretty loose.
I took it apart and put it back together best as I could but still the same issue.
Old 01-11-08, 10:03 AM
j stuff
j stuff's Avatar
bumping up
Old 01-11-08, 10:21 AM
zokustyle
zokustyle's Avatar
have a look at your maf, too.
a disconnected/defective/bad maf will sometimes have the same symptoms.
Old 01-11-08, 10:56 AM
j stuff
j stuff's Avatar
^ thanks will do
Old 01-12-08, 11:38 AM
Harky
Harky's Avatar
Default You might try changing your TPS position...
Before you commit to replacing it, you might try adjusting it slightly.
However, make sure that your idle adjustment is not affected. (There is a small "sweet spot" in the TPS at idle that you can adjust slightly without messing it up) It may improve your engine response.
Old 01-12-08, 10:29 PM
j stuff
j stuff's Avatar
Update
Cleaned the MAF.. it seems the previous owner cleaned it because its actually very clean. Put everything backtogether and still same issue
Old 01-12-08, 11:08 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
very likely it was improperly cleaned...
Old 01-12-08, 11:48 PM
j stuff
j stuff's Avatar
I was told by several people to open it up and clean the mesh looking part. Its basically very clean. Am I doing something wrong? For the life of me i cannot find any tutorial on what exactly to do. Pics would be great.
Been searching for days, if anyone has directions or diy pics itd be great.
Old 01-27-08, 10:11 AM
BIGBADDAD
BIGBADDAD's Avatar
Have you adjusted your TPS yet, just move it 1/32 of an inch either way, without changing the engine RPM, if it makes a difference (fixes it) than your TPS has a wear spot and should be replaced.
Take care.
Mark
Old 01-29-08, 08:34 AM
j stuff
j stuff's Avatar
the tps is the black stick looking thing correct?
saleenssc
17
10-15-16 04:21 PM
dneal92
06-15-16 04:01 AM
90Ls4004JG
12-27-13 07:09 PM
Danny365N
05-28-13 06:54 PM
jimskelton
17
11-03-12 03:46 PM
Quick Reply: 94 LS400 Surges at more than half throttle...
