Looking to get a UCF 21...QUESTION
Old 12-25-07, 04:12 PM
waijai
waijai's Avatar
Default Looking to get a UCF 21...QUESTION
I understand the factory air suspension was an option, but did the LS ever have any "packages" that came with it? Other than looking at the suspension itself, how could I tell if air suspension is installed? I might be looking online for one, and I'd like to only target those with factory air.
Old 12-25-07, 05:04 PM
timer00
timer00's Avatar
Look for the button with HEIGHT Low/Norm/High etc on it next to the PWR button to the left of the gear shift. If you have the HEIGHT type button it has air suspension.
Old 12-25-07, 05:18 PM
waijai
waijai's Avatar
cool, any pics of it you can show me?
Old 12-25-07, 05:26 PM
chubby
chubby's Avatar
ucf21 = most of the time is air ride suspension
and for you fools that think ucf21 means 98-00, you are wrong
Old 12-25-07, 08:41 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
calm down tu, we've already settled this
the OP is looking for factory A/S but nobody's told him to just look for the height adjustment switch next to the shifter
after that you look at the top of the struts (lift the hood...) and make sure it has the TEAS/valves.
Old 12-26-07, 08:15 AM
waijai
waijai's Avatar
Okay well looking to get a 98-00 with air suspension. It seems to be really hard to find so far.
Old 12-26-07, 10:49 AM
chubby
chubby's Avatar
find a platinum series and you should be probably 80% okay
(platinum series = ucf21)
Old 12-26-07, 11:18 AM
Kansas
Kansas's Avatar
A/S doesn't appear to be common on the 2000 Platinum Series or on the 98-00 LS400. I've never seen a 98-00 LS400 with A/S but maybe they are not common here in the central U.S.
I suspect you will find only fully optioned cars with A/S. If the car doesn't have heated seats and Nakamichi or Nav, I doubt if it will have A/S.
Old 12-26-07, 11:37 AM
chubby
chubby's Avatar
platinum series cars for the most part came almost fully loaded. i think heated seats and traction control came standard. the air suspension option did have some "requirements" like traction control though. so basically, if someone is looking for an LS with air suspension, make sure you look at the cars that are fully loaded with every option imaginable
Old 12-26-07, 12:11 PM
waijai
waijai's Avatar
Can anyone get a picture of the air suspension button? This would help me a lot when looking through online photos.
Old 12-26-07, 02:03 PM
PureDrifter
BahHumBug
nope, when my dad was looking for a plat. series LS oh so many years ago we went thru about 30some odd PLATINUM series cars, and not one was with A/S.
outside of the US the "ultra lux" cars that had rear ac controls pretty much always had A/S, but INSIDE the USA the platinum series was just a package with emblems, mono paint (on some colors) plat. floor mats and badges, and a different kind of wood inside. my dad's plat series still says UCF20
Old 12-26-07, 06:54 PM
Kansas
Kansas's Avatar
Most Platinum Series cars I have seen in person, on ebay or on Lexus.com back several years ago when they were still being sold as CPO, have been the lower content SE variation without heated seats and with the standard audio system - no Nak or Nav. All LS400 Platinums have maple wood trim, black pearl exterior badges, textured leather, HID, sunroof, 01 LS430 wheels, Platinum Series floor mats, and those little Platinum Series plaques on the front fenders.
Only Platinum Series cars with Nak or Nav have heated seats: https://www.clublexus.com/forums/sho...light=Platinum
All 98-00 LS400 cars have VSC and "snow mode". As far as I can tell, the only way to emulate the older traction control system is to put the ECT selector into "Snow" mode. What you might call "traction control" is OFF by default on the 98-00 LS400 unless you turn it on by selecting Snow mode. On the 90-97 LS400, traction control was ON by default on unless one pressed the Trac off button.
All 98-00 LS400s I've seen advertised with A/S have had Nak or nav or have been 2000 Platinum Series SF (Nak) or SG (Nav) variations.
Old 12-26-07, 07:07 PM
LiCelsior
Retired
LiCelsior's Avatar
the button is right next to the shifter..u cant miss it. it is clearly labeled HEIGHT and in the trunk there is also a OFF button IF u have air susp.
Old 12-26-07, 07:10 PM
anotherLS
anotherLS's Avatar
heres a clean one in san antonio w/NAV..no air though
http://www.carmax.com/dyn/factsheet/...t.aspx?KNo=167
Old 12-27-07, 08:22 AM
waijai
waijai's Avatar
I think I may just have to find one fully loaded and add air suspension to it.
Quick Reply: Looking to get a UCF 21...QUESTION
