Can Someone Verify This...
I was thinking about installing an aftermarket dvd/nav system in my '96 LS400 and I called up the Metra company because they have a new double din dash kit available. The mechanic I spoke to told me that on any LS400 from at least '95 on, you have to re-wire the entire car to use any aftermarket stereo. IS THIS TRUE? It seems like many people in this forum have just used a wiring harness and hooked right into the OEM speakers. WHat am i missing???
Super Moderator
Completely untrue. Now, I'm not sure if there is an aftermark wire harness for the UCF20/21, but if there isn't you just have to tap the right wires. I did that on my 99. I installed an Alpine IVA-310, removed the stock Nakamichi amp, and kept the stock speakers. I didn't use the stock sub though. I was planning on changing the sub and using a dedicated sub amp, but I never got around to it and I returned everything back to stock since the car should be sold in late January.
so did you have any luck with getting the 2-DIN kit?
That would be very useful. Could you please post a write up with pics?
Thanks
Thanks
Bradster
06-18-07 07:57 PM
dusouth
05-03-07 12:23 PM
LazyAlex
12-13-06 10:37 AM
Rod G
07-22-05 04:37 AM
