Power Steering Fluid Change
Old 12-10-07, 11:24 AM
stroker
stroker's Avatar
Default Power Steering Fluid Change
Changed my oil today (Mobil 1) and while checking other fluids looked at P/S fluid and it felt kind of gummy...How do I drain or remove fluid from reservoir and what type fluid should I use?? Is there some kind of filter in the system somewhere??? Thanks, Stroker
91 LS400
Old 12-10-07, 01:42 PM
PK_Celsior
PK_Celsior's Avatar
http://www.lexls.com/tutorials/steering/psflush.html that should answer your question
Old 12-11-07, 08:33 PM
Bill Dowd
Bill Dowd's Avatar
I bought a pump at pepboys and I sucked out the oil and used dexron trans fluid ran the car for a couple of minutes then sucked out the fluid again did this 5 times till the fluid was nice and red use about 2quarts of trans fluid doing this. I now use mobil one synthetic transmission fluid to change my power steering fluid it runs cooler for the power steering pump and helps keep wear down hope this helps
Old 12-11-07, 08:46 PM
stroker
stroker's Avatar
Thanks PK Celsior and Bill Dowd for your fast and helpful reply.. Doing it tomorrow and will post results,,Thanks again, Stroker
aypues
06-16-14 05:21 PM
bob2200
RX - 1st Gen (1999-2003)
02-10-14 08:10 PM
JonCAGS300
GS - 1st Gen (1993-1997)
01-06-08 07:51 AM
Purplexed
Maintenance
05-26-01 06:16 AM
Quick Reply: Power Steering Fluid Change
