tIs there a way to disconnect he power to the antennae?
Old 11-25-07, 01:37 AM
1995LS400
1995LS400's Avatar
Default tIs there a way to disconnect he power to the antennae?
My antennae makes a wierd noise everytime I switch from CD to radio. It seems like it is not connected to whatever it is that makes it go up and down. Can I disconnect some wiring so that it will stay up at all times? I am not getting very good radio reception due to the fact that the antennae is only like 16-18 inches up, and it never pulls down flush with the LR body panel when the car is off. BTW, how far will the antennae go up if it is functioning normally? And, if I do disconnect any wiring, will I be able to pull up on the antennae so that it is as high as it will go for good radio reception?
Old 11-25-07, 01:40 AM
1995LS400
1995LS400's Avatar
Mods, please put the lower case t in the Thread starter to where its supposed to be, thanks.
Old 11-25-07, 05:42 AM
Griffin400
Griffin400's Avatar
The the power cable off the antenna when its up and that should work.
Old 11-25-07, 11:22 AM
PK_Celsior
PK_Celsior's Avatar
does it make a loud cracking noise when ti goes up. i had the same with my 95 ls400. what happen is that the mass for it finally though of giving up and broke lol. simple fix just get a new mass. yea just power up the antenna reach in your trunk. yank that power plug.
Old 11-25-07, 08:36 PM
ttyR2
ttyR2's Avatar
Lexls.com has a replacement guide for changing out the antenna mast. It's simple and cheap.
Old 11-29-07, 08:22 PM
Bill Dowd
Bill Dowd's Avatar
If you don't want to to change out the antenna I just unhooked my in the trunk just under the antenna there is some carpet on the fender well just pull it back and unhook the power plugs that go to the motor of the antenna. I just pulled mine up fully and no problems and good radio sounds.
Old 11-30-07, 04:05 PM
turbosix
turbosix's Avatar
the antenna looks retarded when its stuck up and most likely will get ripped off by some ******* while you're parked
most stations in dallas come in just fine with the antenna down, the only time i have issues are when i'm in tunnels or parking garages.
Finn
01-12-14 11:57 AM
icey white
05-25-06 06:22 AM
Vpking77
05-26-01 06:30 AM
Quick Reply: tIs there a way to disconnect he power to the antennae?
