a/c problem '00
Old 11-17-07, 09:29 PM
CO-LS400
CO-LS400's Avatar
Default a/c problem '00
For some odd reason my A/C only works if I put it on "Max Cold" 65 degrees.
If I move it any higher hot air blows out??
Any help.. its driving me bonkers.
Thanks
Old 11-18-07, 12:10 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
could be your interior temp sensor is either clogged, or not plugged in. Its right above the drivers right knee behind a little small screen.
Open it up, clean it, or make sure its plugged in.
Old 11-18-07, 09:23 PM
CO-LS400
CO-LS400's Avatar
Ahh haa.
Will check that out this weekend.
Thanks
I hope that is what it is.
I noticed it after I had an aftermarket gps system put in.
I bet the installer unplugged something.
Thanks
Old 11-26-07, 08:49 PM
CO-LS400
CO-LS400's Avatar
Thank You!! that was it! The installer probably didn't plug it in.
It was just hanging there. Plugged it in and now it works!!
Old 12-18-07, 08:21 PM
Bill Dowd
Bill Dowd's Avatar
Here is an A/C tip in the winter run the compressor you can have on the heat and turn on the ac switch for about 5 to 10 minutes. This helps the oil and freon mix keeping your A/C system running for years. When you turn on the A/C compressor it will not get cold the heat will keep it warm unless you turn down the temp then it will really get cold.
Ktreece777
01-17-13 04:31 PM
nfordhk
SC- 1st Gen (1992-2000)
09-27-10 03:41 PM
edwinbong
Performance & Maintenance
10-20-09 09:49 PM
cutecboy
10-19-02 09:13 PM
Din
06-05-02 12:02 AM
Quick Reply: a/c problem '00
