91 ls 400
Old 11-16-07, 08:56 PM
poicow
poicow's Avatar
Default 91 ls 400
i just noticed that when i put on the high lights it doesnot come on, also the fog lights don't come on, but the regular lights works fine, any suggestions thanks
Old 11-16-07, 11:18 PM
Bali26
Bali26's Avatar
Check your fuses and bulbs. Directions are in the owners manual. Cheers
Old 11-17-07, 05:54 AM
trukn1
NELOC Mod
trukn1's Avatar
Sounds like you may need to check the fuses , as stated above. As far as the high/low not working it sounds like the high side terminal in the bulb itself may be dead. You have a first gen LS (89-94), like myself, and that bulb for the healight is also the bulb for the high beams as well. 1 single bulb. If the low side is working, and the high side is not, sounds like the terminal inside of the bulb may be broken, and you need to replace the entire bulb. Concerning the foglights,, check the fuse if it does not come on a all. Fuse for the fogs is located on the fuse panel inside car on the driver side, under the dash, by the brake pedal. Start there, as it is the easiest to access.
TurboDooze
01-10-18 12:23 PM
estone
08-22-17 10:28 PM
brainshowe
09-06-15 06:32 PM
S-Lex-95
03-07-11 02:58 PM
Low Offset
Lighting
04-13-09 10:48 AM
Quick Reply: 91 ls 400
