How hard is it to change your own lowering springs?
Old 10-29-07, 11:47 PM
1995LS400
1995LS400's Avatar
Default How hard is it to change your own lowering springs?
At my Refrigeration company, we have an on duty mechanic that does all the maintenance on work vehicles. He also races and works on late models and sprints for dirt tracks. Im in good relation with the guy, just wondering if he is capable of working on a Lexus, when all day he is working on mostly domestic work vans and pickups? Would you trust someone that normally doesnt work on too many imports to do your work?
But most importantly guys, could I do this myself with a spring compressor? Have any of you done this yourself?
Old 10-30-07, 12:39 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
ive done mine like 2-3 times now, the worst part, in all honesty is 2 thing.
-taking apart the rear seat to get to the rear spring mounts.
-in the front, taking off the upper balljoint, and in the back, angling the shock body so you dont have to pop the balljoint.
Old 10-30-07, 01:13 AM
PureDrifter
BahHumBug
Originally Posted by LexusToys
daym that mean the rear similar to ES then and yes it is a b**** to do that. Be careful with all your panel if you try to do it yourself.
its not THAT bad, you are only taking out 3 things, the seat bottom, the seat back, and then removing, (or just tilting up) the rear parcel shelf.
Old 10-30-07, 06:19 AM
steveski
steveski's Avatar
The rear seat was and is the worst part of the job for me I rented a pitman arm puller and spring compressor from Autozone for $0 and like Pure said it takes a few hours. I have done mine twice now.
Old 10-30-07, 11:23 AM
chubby
chubby's Avatar
did mine 5 times. it's a *****
Old 10-30-07, 11:41 AM
PureDrifter
BahHumBug
its not THAT bad, did you have to remove the ball joint in the rear?
how bad was it to install your airsusp? hardest part i imagine was running the airline
Old 10-31-07, 05:58 AM
19psi
19psi's Avatar
i concur, the back seat is the worst part!
otherwise, i can do the fronts in about 10 minutes per side. the rears take about 30 minutes per side. i don't pop anything else apart though, i just work it out of the holes.
i do have the advantage of being a lexus tech and using the shop for my own car though!
i'm sure your guy can do it.
Old 11-01-07, 02:38 PM
pfantom68
pfantom68's Avatar
Backseat was pretty bad for me... and the swinging of the rear strut just right so it can come out. All in all, not a difficult project if you have the right tools on hand and a good amount of time.
Also, for the fronts, my friend and I just unbolted the upper control arm instead of playing with the ball joint.
Old 11-01-07, 07:37 PM
909LS
909LS's Avatar
yeah i gotta agree the hardest part is getting the upper part of the back seat out! other than that it pretty straight forward...
JL004
Suspension and Brakes
09-13-17 09:03 AM
DaKi3241
09-12-13 05:58 PM
Stormforge
Suspension
36
10-11-12 06:40 PM
ajs14
03-07-05 10:13 AM
bigbllr2000
06-19-02 10:02 AM
Quick Reply: How hard is it to change your own lowering springs?
