Ls400 New Info On Problem
Old 10-15-07, 12:59 PM
JFLACO610
JFLACO610's Avatar
Default Ls400 New Info On Problem
1st i wanna thank every1 who's replied to my questions. recently i posted about cleaning my throttle body & now my 91 ls wont start. I have to apologize for not mentioning my mess up 1st. there were no gaskets available near me so i bought the gasket material and traced it off the throttle body, but when i put it on i didnt cut out the hole for the "flapper" in the t/b. the car started perfectly, but when i hit the gas it stalled because i didnt realize i didnt cut the hole out, does any1 have any idea what might of happened cuz again this mechanic said because the (check engine) light DOESN'T...AGAIN DOESN'T COME ON THE CAR WON'T START. i told him what i did & he just kinda gave me this lookwith no words. by the way nj mechanics take forever to look at your car. i have it somwhere else now & hes had it for 6 days, no look yet
Old 10-15-07, 01:12 PM
trukn1
NELOC Mod
trukn1's Avatar
First,, go back and retrieve your car from this yea-yo mechanic b/c he has absolutely no sense of what he is doing. If your car is gonna get screwed up, am sure you can do it all by yourself with no help from him. LOL!!!
Second, do any of the lights on your dash come on when you turn the ignition? They should come on for a brief second and then disappear when the car is started.
Not quite sure why it still will not start now that you have corrected your mistake. Please keep us informed.
Old 10-15-07, 02:23 PM
sonyman
sonyman's Avatar
That was a very silly mistake, but at least it was an honest one. Hopefully you'll be driving her again soon.
Old 10-15-07, 02:33 PM
JFLACO610
JFLACO610's Avatar
Default (carlos mencia)
lol!! yea i know i feel like a cross between patrick from spongebob & tim the tool man. im gonna go to the other place i have it & let u know about the lights. i believe all of them come on when i turn the key, the car still cranks & seems so close to starting!
Old 10-15-07, 03:37 PM
JFLACO610
JFLACO610's Avatar
Default Update....!!!
Ok, I Went To The Other Mechanics Place The Cars At & The Lights That Come On Are The Seat Belt, O/d Off, Oil Light, Brake Light, & That Yellow Light On The Bottom Left That Looks Like A Castle Or Somethin, Than Some Stay On & Others Go Off
Old 10-15-07, 04:12 PM
LiCelsior
Retired
LiCelsior's Avatar
you might need to pull the codes. http://www.lexls.com/tutorials/intro/codereading.html follow the directions to do so.
Old 10-15-07, 04:24 PM
JFLACO610
JFLACO610's Avatar
well i guess ill have the mechanic that has it do that, i already pulled it out so he has access.
Old 10-15-07, 07:06 PM
JFLACO610
JFLACO610's Avatar
u know, i gotta read these replies more thoroughly, thanks for the link, i didnt see it at 1st.
Old 10-16-07, 05:39 PM
JFLACO610
JFLACO610's Avatar
Default Checked Codes!!
Ok, I Checked The Codes As They Said In Lexls.com. Engine & Tranny I Got Nothing(o/d Off Light Blinks Continuously) For The Abs/air Bag/trac Codes I Also Got Nothing(anti Lock & Cruise Main Continuously Blinking). I Dont Know If Theres Any Other Ways To Check Other Codes As This Is All They Provided In Lexls.com. Still The Car Wont Start And Now For Some Reason THE BATTERY IS DEAD P.s. I Bought A New Battery For It A Week Ago & Its Dead Already(feels Like Ghost In The Shell) Anybody?!? Ty
Old 10-16-07, 10:06 PM
skperformance
skperformance's Avatar
Hmm sounds like your alternator is your problem causing all the lights when stopped , is your power steering leaking?
Old 10-16-07, 10:45 PM
JFLACO610
JFLACO610's Avatar
car doesn't run & b4 this it started no problem. power steering was leaking but the problem was fixed b4 this started(plugged pump & sealed vacuum lines) & after the lesk was fixed it started right up. its wasn't til i started the car & the throttle body was blocked this occurred.
Old 10-17-07, 09:06 AM
ewenpg
ewenpg's Avatar
Yep I'd say dead alternator
Old 10-17-07, 04:08 PM
JFLACO610
JFLACO610's Avatar
i know ur probably tired of hearin this but "mechanic says" he was tryin to crank it which is why the battery is probably dead & the car did the same thing, it started for a split second than shes kaput. im gonna give him till monday the latest than im takin her back(monday will be 12 days). wouldnt the alternator show on the codes??
Old 10-18-07, 06:56 PM
PlatanoTLS
PlatanoTLS's Avatar
Yo Flaco where you from, sounds like you need a decent mechanic
Old 10-18-07, 10:30 PM
JFLACO610
JFLACO610's Avatar
central nj platano, yea not decent, just som1 who can listen to what i did n fix da damn problem, i need this ls for school/kids. hit me up or pm me wit a #
Quick Reply: Ls400 New Info On Problem
