EGR delete problem
Old 09-29-07, 09:50 AM
thebeeguy
thebeeguy's Avatar
Default EGR delete problem
So I deleted my EGR (No i didnt buy the lextreme kit). But I followed directions I found on this site. My question is, which plug do I put the resistor in? There are 2 plugs that go to the EGR, one toward the front of the engine (right next to the Diagnostics port), and 1 toward the back attached to the VSV.
Also, the resistor is supposed to be a 10k Ohm 1/2 watt resistor correct?
I put a resistor in the plug that was attached to the VSV, and the check engine light for the EGR came on a day later.
I then put resistors in both plugs and the same thing, a day later the EGR code comes back up.
Am I using the wrong resistor or something?
Old 09-29-07, 10:03 AM
thebeeguy
thebeeguy's Avatar
Nevermind I'm an idiot. It goes in the plug that is directly under the intake manifold where the EGR bolts to the manifold. I didnt even notice it when I deleted the EGR
1UZFE_SC95
Performance & Maintenance
27
07-10-21 12:53 PM
hbradberry
02-22-19 08:06 AM
yauny
02-07-17 06:31 PM
mk4r34
04-23-13 02:16 PM
motorheaddown
12
07-09-12 10:31 PM
Quick Reply: EGR delete problem
