car starts (w/ jump) but NOTHIN else works
Old 09-04-07, 07:05 AM
Iansaltes
Iansaltes's Avatar
Default car starts (w/ jump) but NOTHIN else works
92 LS.... I dropped a wrench down in behind the battery, and I was gonna take it out to remove the wrech later. got it all back together.... now the car wont start without a jump AND when it does run... NOTHING else works, no lights, no dash, my a/c, no cd player.. nothin.
Whats the deal!?!?
Old 09-04-07, 07:26 AM
Iansaltes
Iansaltes's Avatar
ok guys.... now I really feel STUPID.
In the "heat" of the moment, I accidently reversed the + and - cables. It's raining outside and I quickly threw it together, thinking I knew which was the correct way. Turns out the SOB is backwards, hence my problem.
I hope there is a "quick fix" for this....but I know it will be difficult.
Help anyone?
Yay... go me.
Old 09-04-07, 11:04 AM
LS4
LS4's Avatar
so is the problem gone now, everything working?
Old 09-04-07, 12:16 PM
illcelsior
illcelsior's Avatar
Help anyone?
Quick fix other than reversing the cables??
Did you damage something in the heat of the moment????
Old 09-04-07, 12:18 PM
Iansaltes
Iansaltes's Avatar
eh, kinda. I replaced the 120A circuit breaker.... now it starts up and runs...idles very low, interior lights dont work, airbag light is on, cd player doesnt work (aftermarket, if probaly the fuse in the back, I hope).
Also, the steering wheel doesnt adjust... do you have a fix for that?
Old 09-04-07, 12:29 PM
illcelsior
illcelsior's Avatar
oh geez.. Sounds like you fried a LOT of fuses.
Check both fuseable links as well as fuse kick panels.
Old 09-04-07, 01:33 PM
Iansaltes
Iansaltes's Avatar
Yeah I really did.... probably 6 fuses, and two circuit breakers. and it killed my battery...
I got it all workin now... it just runs alittle rough and airbag light is on...
Old 09-04-07, 07:42 PM
absolut
absolut's Avatar
check your alternator fuse. The same thing happened a few weeks ago when I changed my battery terminals.
Old 09-04-07, 08:29 PM
avalon42
avalon42's Avatar
Hopefully you won't have to do that wire dance to take the airbag light off...
Old 09-05-07, 05:59 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Search up for the procedure to get rid of the airbag light. I think its on lexls.com.
It wont go away until you reset it. (everythign else is fine though) Happens a lot when you replace the battery.
Old 09-05-07, 06:34 PM
Iansaltes
Iansaltes's Avatar
I noticed when I started my car that I smelled something weird...
I hope its just the coolant I spilled burning off.....
car0401
SC- 1st Gen (1992-2000)
02-22-16 04:56 PM
xaper
15
06-17-14 01:42 AM
Raiderace
01-12-12 09:49 AM
nfordhk
Performance & Maintenance
02-04-10 05:13 AM
Iron Sheik
09-01-05 11:41 AM
Quick Reply: car starts (w/ jump) but NOTHIN else works
