In an effort to improve gas mileage...
Old 09-03-07, 06:46 PM
black_LS
black_LS's Avatar
Default In an effort to improve gas mileage...
since 15.4mpg doesn't seem to good compared to the rest of you guys, I'll try the following.
1. Seafoam it - I've heard great things, why not try it?
2. Change the oil - 5w-30 - synthetic or no? I'm not sure what the PO used.
3. Change the spark plugs - NGK BKR-6EIX
4. Change the spark plug wires - NGK TE119
5. Air filter - K&N - Lexkost mod, if it's not too noisy for my tastes.
6. Change the fuel filter.
7. Distribution caps? - Worth it?
8. Clean the throttle body.
If that doesn't work...
9. Change the injectors.
10. Change the O2 sensors.
Tell me what you guys think. Any input is appreciated!
Old 09-03-07, 07:28 PM
sonyman
sonyman's Avatar
1) I assume you mean through a vacuum line. Do it. Cheap but maybe not so effective.
2) 5W-30, synthetic or not is more of a preference. A high quality dino should do fine. With that said, I use Mobil 1 EP 5W-30.
3) NGK or Denso, platinum or iridium will work fine.
4) I recommend using OEM wires.
5) I personally don't trust K&N's ability to filter fine particles. I'd stick with the OEM airbox and a genuine Toyota air filter.
6) This won't affect mileage unless your filter is clogged, so I'd skip it.
7) Worth it when you're changing the plugs and wires. Change the caps and rotors.
8) Definately.
9) A bit drastic and most definately unnecessary.
10) Check yours first as new ones may or may not affect your mileage.
Old 09-03-07, 07:33 PM
Suneet
Suneet's Avatar
I've done everything listed except 9 and 10, and I haven't changed the fuel filter.
I get about 17-18mpg average on a tank, or about 320-350 miles on a tank, depending on how much freeway driving I've done. In the Bay Area, you get a good mix. I woudln't say 50/50, maybe like 70/30 in terms of mileage, and the opposite in terms of actual time on the road =P
Old 09-03-07, 07:50 PM
black_LS
black_LS's Avatar
I guess I'll just check the fuel filter then.
BTW, my 15.4mpg is based on 100% city driving.
Have you guys changed anything else that I've left out?
Old 09-03-07, 07:57 PM
BiGLeX 400
BiGLeX 400's Avatar
You can try bumping your tire pressure up a little bit.
Old 09-03-07, 08:14 PM
Thermactor
Thermactor's Avatar
give the car to me for a week and i'll get 20mpg out of it in all city driving. it's all about YOU and your foot. get a Scangauge and it'll tell you your mpg in real time.
Old 09-03-07, 09:26 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
15.4mpg city is pretty much what i got in my old '95
seafoam and spark plugs i would do, check the resistance ofn the wires and see if u really need to change them.
the rest is kinda maint. aanyways, do them on ur own time
Old 09-04-07, 02:11 PM
Blavatsky
Blavatsky's Avatar
Yeah I get about 15-16 city with my 99....should be better (?), I need to do at least half that list , once I'm done being broke as usual.
Old 09-04-07, 02:17 PM
sonyman
sonyman's Avatar
Originally Posted by Blavatsky
Yeah I get about 15-16 highway with my 99....should be better (?), I need to do at least half that list , once I'm done being broke as usual.
It should be quite a bit better than that.
Old 09-04-07, 03:00 PM
PureDrifter
BahHumBug
15-16 HWY ?
i get at LEAST 22 on an 80-85mph cruise
Old 09-04-07, 03:43 PM
Samhutto
Samhutto's Avatar
Default Wow!
15-16 with a '99!?
I just got my license and have a 94 es 300, and I get 19.5 city. Thats just school, work, home, school, work, home. I would definitely get that checked out..
Old 09-04-07, 04:37 PM
PureDrifter
BahHumBug
Originally Posted by Samhutto
15-16 with a '99!?
dont compare, the ES300 is a FWD V6 car thats pretty damned light.
the LS400 weighs damn near 2 TONS is RWD and has a 4.0L V8
my beater '90 Camry V6 pulls damn near 21mpg city on regular
Old 09-04-07, 05:13 PM
illcelsior
illcelsior's Avatar
You may want to check the o2 sensors first- not last on the list.
Most importantly- train your foot. Most loss in MPG comes from heavy foot.
15-16 with a '99!?
Why are we comparing rotten apples to ripe oranges?
Old 09-05-07, 05:50 AM
Blavatsky
Blavatsky's Avatar
15-16 HWY ?
Ooops, fixed that post...15-16 city I meant durr sorry.
I've gotten as high as 27 on cruise control going 80 on hwy.
Old 09-05-07, 05:54 AM
Iansaltes
Iansaltes's Avatar
I get 15.9mpg ALL city on my 92 LS4
Quick Reply: In an effort to improve gas mileage...
