Maintenance Question (distributors and rotors replacement) '95
Old 08-02-07, 04:11 PM
LexChamp
LexChamp's Avatar
Default Maintenance Question (distributors and rotors replacement) '95
I am looking to change the plugs and wires on my 95 LS. I also have to change the timing belt, water pump cap and rotors too in the near future. The question I have is should I change the distributors and rotors when I change the plugs of when the timing belt is change. I have OEM plugs and wires. Should the rotors and distributors be OEM, or can I get them from the local auto shop. Thanks
Old 08-02-07, 06:01 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
OEM is best bet.
contact carson toyota for best prices on OEM parts
talk to Luis or Steve
Old 08-02-07, 08:22 PM
LexChamp
LexChamp's Avatar
Thanks Pure. How about changing the distributor and rotors when changing the wires and plugs or changing them when doing the timing belt.
Old 08-03-07, 12:18 AM
PureDrifter
BahHumBug
if ur changing wires u already have it all apart so you may as well.
why replace the whol dist. if it isnt broken tho? just cap and wires should be fine.
Old 08-18-07, 11:32 PM
Bill Dowd
Bill Dowd's Avatar
I saw your question I have been lucky to meet some of the teachers at the lexus training center here in California and here is what I was told at around 100k change the wires rotors distributor caps water pump timing belt lower crank seal all the belt pullys just as sure as you don't change one of these something will go out and the labor will cost all over again. Also have your auto shop person drain the radiator and the block and put in Toyota antifreeze with distilled water 50/50 mix change out the power steering fluid and if needed the trans fluid and rear end oil remember you take care of your lexus and it will take of you.
Old 08-19-07, 12:33 PM
sonyman
sonyman's Avatar
The manual specifies a 90k interval for the distributor rotors and caps. That is what I would follow.
Old 08-19-07, 05:16 PM
Lexkost
Lexkost's Avatar
I justed changed all the above and more @134,000 all the parts removed look very good except the caps and rotors.
But I used all OEM.
Old 08-21-07, 11:08 AM
steveski
steveski's Avatar
Pure is right - call Luis or Steve at Carson Toyota. I just got more parts from Luis and their OEM prices were close or the same as aftermarket prices.
Old 08-21-07, 11:10 AM
steveski
steveski's Avatar
But I used all OEM.
And Mike your car looks like new bro!
Old 08-24-07, 06:30 PM
PK_Celsior
PK_Celsior's Avatar
Yea I Just Changed Out My Cap And Rotors. Put A Lil Pressure On My Radiator And It Broke. Ehhhhhh. Haha. Guess Gota Learn From Mistakes
damon
Maintenance
11-25-04 10:38 AM
sweetsc400
Performance & Maintenance
05-19-04 02:52 PM
One HoT
Maintenance
12
12-29-02 11:51 PM
The Ikon
Maintenance
12-08-01 02:33 PM
The Ikon
11-29-01 10:07 AM
Quick Reply: Maintenance Question (distributors and rotors replacement) '95
