LS400 wheel offset??????????????
Old 06-24-07, 03:49 AM
OzLS400
OzLS400's Avatar
Default LS400 wheel offset??????????????
Hey all. This is my new baby. Pick it up this week. 1998 model with only 81,000klm's (50,000 miles). I'm looking at a set of 19x8's +35 offset (see reply from seller below). Do you think I will have any problems with tyres rubbing? I'll post some pics of wheels later.
HI THERE MATE
THE LEXUS IS A BIT OF A ODD FITTMENT THESE WHEELS HAVE A OFFSET OF 35MM AND YOUR CAR HAS 45MM WHICH MEENS THEY WILL SIT ABOUT 10 - 15 MM CLOSER TO YOUR GAURDS SO IF YOU HAVE CHECKED IT OUT YOU SHOULD HAVE THAT MUCH ROOM BUT WILL NEED TO CHECK THAT AGAIN BEFORE YOU GO FOR ANYTHING NORMALY CARS DO HAVE THAT MUCH ROOM AND THESE ARE GOING TO BE A BETTER FIT THAN THE OTHERS WE WERE TALKING ABOUT ALSO I WOULD PUT A 235/35X19 TYRE ON INSTEAD OF A 245/35X19 AND THIS WOULD HELP WITH YOUR FITMENT !!
Old 06-24-07, 04:00 AM
OzLS400
OzLS400's Avatar
This set come in 18's or 19's. What do you think. By the way this is the new Holden Commodore SS V8 that will be coming your way as the Pontiac G8 later this year. Oz made muscle car. You can see them at www.bbosswheels.com Nice wheels.
Old 06-24-07, 04:03 AM
OzLS400
OzLS400's Avatar
These wheels are the +35mm offset that I'm worried about. 19x8's. What do we all think?
Old 06-24-07, 04:09 AM
OzLS400
OzLS400's Avatar
These are the BBOSS wheels on a IS Lexus. Look neat hey? These come in +45mm offset so they assure me that they will fit with no problems. I'm leaning towards these but I like the deep dish as well. Any thoughts would be greatly appreciated.
Attached Thumbnails LS400 wheel offset??????????????-sylvia-8_hyper_lexus.jpg
Old 06-24-07, 02:04 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
not the offset thats the problem, make sure u ask the manufacturer if they are positive that the wheels will clear ur brakes.
the brakes on the 98-00 Celsior/LS400 are HUGE, bigger even than those found on the 93-98 MKiV Toyota Supra Turbo.
Old 06-24-07, 02:16 PM
NJ240sxMan
NJ240sxMan's Avatar
In the front I'd go with a 235 tire, rear you can go 245 and you'll be fine.
Like Pure said, make sure the wheels have a spoke design that will allow the wheels to clear the massive brake calipers that the ucf20's have.
Old 06-24-07, 02:44 PM
UCF20
UCF20's Avatar
this are conservative offsets in my opinion. +35 is weak, you would be able to clear +25 to +30 on a 19x10 in the rear without any fender modifications. trust me i know because i thats what i ran on my 96 LS400. 19x8 is definitely going to make the wheels look sunken in because they are. figure, 2 inches on the width of the wheel with a high offset like that, you're going to be seeing alot of gap between the wheel and your fender. in my opinion, if you are going with those wheels, place some 40mm spacers. which would result in a 19x8 -5 offset but hey at least it will look flush and have great fitment. =]
Dustyy (12-16-23)
Old 06-24-07, 04:21 PM
PureDrifter
BahHumBug
the 2LS can run 245/40/19 F and 275/35/19 R. More room/clearance than 1LS
Dustyy (12-16-23)
Old 06-25-07, 02:17 PM
vredniykot
vredniykot's Avatar
i just tried 20x8 +20 offset on the front the other day and it stuck out 1 1/2 inch past the fender
i got 20x8 +40 up front and 20x10 +35 in the rear, both sit just even with the fender edge
Dustyy (12-16-23)
Old 06-26-07, 07:45 AM
illcelsior
illcelsior's Avatar
It's not just offset that determines the fit of the wheel. Wheel width plays a MAJOR part. You cannot simply go by offset alone.
18x7 @ +35 & 18x10 @ +35 are waaaaay different.
Use a wheel/tire calculator.
Dustyy (12-16-23)
Old 06-27-07, 12:02 PM
19psi
19psi's Avatar
the front will fit ok as long as the spokes clear teh caliper, but the rear will look sunken in. you should try for a wider rear wheel with about +30 in the back if you go with a 10" wide.
RC5
RC F (2015-present)
23
04-19-19 05:24 AM
mball19
Wheels, Tires & Brakes Forum
05-07-13 08:40 AM
ThisIsIt20
11-20-11 04:07 PM
TurboSam
02-19-07 10:33 PM
spinout180
20
12-06-04 09:13 PM
Quick Reply: LS400 wheel offset??????????????
