91 ls 400 A/c Which valve
Old 06-05-07, 11:05 PM
jsconiers
jsconiers's Avatar
Default 91 ls 400 A/c Which valve
can any one describe the correct valve to connect a recharge kit. there are two and I want to make sure I have the correct one.
Old 06-06-07, 12:05 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
you cant use a recharge kit available in store since u have an older R12 aka Freon air conditioner.
recharge kits from local autoparts stores are 99.9% of the time made for R134a coolant, which is totally different and NOT interchangeable. want more info? search.
Old 06-09-07, 01:14 PM
trukn1
NELOC Mod
trukn1's Avatar
Pure drifter is correct. Our first gens use the older R12 refrigerant and cannot be purchased at a store. Best suggestion is to have the old refrigerant pumped out, a dye test done to assure that there are no leaks in your A/C system and then come back in a few days, provided no leaks are present, and have your system converted to the R134 refrigerant. I had mine converted already, but unfortunately I have a leak and will need to replace compressor and condensor.
BTW, got off topic a little. To answer your original question, the high pressure side of the system, side which needs to be filled, is the valve closest to the firewall on the passenger side.
gr8fulRed
07-02-18 07:19 AM
Xaelle
08-22-14 05:21 PM
lowKut
08-28-09 11:51 AM
Frankinaustin
Maintenance
01-10-03 05:09 PM
Herm
Maintenance
11-23-02 01:02 AM
Quick Reply: 91 ls 400 A/c Which valve
