climate control problem
Old 05-12-07, 07:25 AM
joetek
joetek's Avatar
Angry climate control problem
climate control does not power on anymore also the clock and out side temp. if anybody knows what wrong please help . thanks
Old 05-12-07, 12:55 PM
skperformance
skperformance's Avatar
What year?
Old 05-12-07, 01:57 PM
joetek
joetek's Avatar
its a 96 ls 400 it was workin fine until i plug in the car charger but there were no blown fuses
Old 05-12-07, 03:31 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
check BOTH fuseboxes VERY carefully...
Old 05-12-07, 03:34 PM
joetek
joetek's Avatar
i only see the one under the hood. where is the other one at???
Old 05-12-07, 03:48 PM
PureDrifter
BahHumBug
driverside footwell.
Old 05-12-07, 03:56 PM
joetek
joetek's Avatar
thanks i'll check i out
Old 01-28-08, 03:28 PM
PR FIEBRU
PR FIEBRU's Avatar
Update on this post. did the fuse fix the problem. My buddy is about to buy a 95 ls but is not sure because the climate control is out. Not Heat or A/c
I found this info on another post....
" the "FR CIG" fuse DOES also power the Front Cigarette Lighter along with the entire Climate Control System. Same area, so they did that. The Lighter is FU and shorts out, but I am getting about 40 miles per fuse."
Old 01-28-08, 03:43 PM
PK_Celsior
PK_Celsior's Avatar
i had that same problem with my ls400. my cousin plug somethin into the cigarette lighter. it was lose and short circuited the fuse inside. so i had to replace it a couple of times. than it work all over again. check the fuse box inside tha car usually thats the one that blows.
Old 01-28-08, 04:02 PM
PR FIEBRU
PR FIEBRU's Avatar
that is crazy. what was toyota thinking when they did that. It does not make any sense to set up the entire climate control system with the cigarette lighter.
Thanks.
Devor
SC- 1st Gen (1992-2000)
03-05-11 05:35 PM
lexusls95
09-22-10 05:03 PM
thinhthan
16
05-31-08 09:14 PM
messysc
11-06-04 05:39 PM
lexman680
08-26-04 07:50 PM
Quick Reply: climate control problem
