HELP!!! Question about installing aftermarket radio to replace broken nakamichi
Old 05-08-07, 06:44 PM
manufan101
manufan101's Avatar
Default HELP!!! Question about installing aftermarket radio to replace broken nakamichi
Hello,
I have a 1995 LS400 with nakamichi. The nakamichi head unit has stopped working (turns itself on and off, switches b/w modes etc..) and cannot be fixed. I want to install an aftermarket head unit for the minimum cost. The guy at Best Buy said he thinks I can just plug my the new head unit into the nakamichi amplifier If I can find an "amplifier integration harness or wire harness for my car. so far I have been unable to find any that specifically say they will work with my car. HELP do such things exist?!!!? I'm having trouble finding anything, PLEASE help.
Thanks
drew
PS the wire harness would be most useful if it had rca cables coming out the back. Attached are pictures of the connectors in my car one of which (I believe the white) will have to fit in the harness.
Attached Thumbnails HELP!!! Question about installing aftermarket radio to replace broken nakamichi-connectors.jpg
Old 05-08-07, 06:50 PM
Craig B
Craig B's Avatar
A friend of mine bought the factory head unit cheap on Ebay. You might try looking for a factory head unit.
Craig
Old 05-08-07, 06:54 PM
Craig B
Craig B's Avatar
I just looked on Ebay. Someone has the harness you're looking for...
Craig
Old 05-08-07, 07:13 PM
Brandicus
Brandicus's Avatar
http://www.lexls.com
look it up in the tutorials
Old 05-08-07, 07:44 PM
Och
Och's Avatar
You don't need the harness, it isn't fully functional, and you loose the subwoofer. Better off hard wiring it yourself. Check audio tutorials on retrodrive.net, it has all the wiring diagrams for the factory LS400 radios.
Old 05-09-07, 12:03 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
2LS stereo is setup slightly differently from 1LS. you will need to custom wire it. use the repair manual link at the top of the forum and it has wiring diagrams for your car as to which wires are what in that harness.
Old 05-09-07, 12:37 PM
Brian Zado
Brian Zado's Avatar
i hard wired my kenwood dbldin radio into the nakamichi amp, I cut the harness and soldered rca ends to the inputs and my factory sub still works and system sounds pretty good for a 95.
Old 05-13-07, 12:50 AM
LS400_Fan
LS400_Fan's Avatar
Brian I sent you a Private Message, if you get a chance to respond it would be much appreciated.
thanks
Old 05-20-07, 10:25 PM
vinegaroon
vinegaroon's Avatar
Too bad you don't need a 1st generation Nakamichi head unit, as I am taking
one out of my 93 that works great. I don't think it will fit into the dash, but
I could be wrong. Perhaps the facia could be switched. I really think you
should look for a replacement Nakamichi head unit. I found mine at a local
radio installation store which had a bunch of used factory units. If you live
in a good-sized city, there should be salvage yards which could sell you a
used unit that you could plug right in to check out before you buy it. That's
what I did. I just wouldn't want to start cutting wires and all that when you
could just plug in a replacement unit. Look on the web too. With all the
folks smashing up their cars on a regular basis, there are plenty of radios
out there. I'll let you have mine for $150 if it will fit.
Old 09-18-10, 07:42 AM
Dre20032
Dre20032's Avatar
Hey Brian I would love to know how ya did it.. cuz i'm in the same Boat!!!
Old 09-18-10, 09:00 AM
jerryparks
jerryparks's Avatar
I would give $50.00 for that Nak unit. $150.00 is out of my price range.
Old 09-18-10, 01:55 PM
vinegaroon
vinegaroon's Avatar
Default Nakamichi head unit
I still have a first generation (90-94) Nakamichi head unit that works just fine
that I will let go for $100. It's a sure bet rather than trying to wire in an
aftermarket unit.
Old 09-18-10, 02:54 PM
jerryparks
jerryparks's Avatar
If you dont get any takers at $ 100.00, maybe later you can consider
my offer. Sorry I cant offer more. I was considing just buying a cheap
Unit and also purchase the kit and wiring adpater kit. The whole thing
is less than $ 100.00, and I would have peace of mind, as these old Nak units are potential reliability problems. Does the CD changer and CD holder
go with the unit?
Old 09-19-10, 05:46 AM
mkaye
mkaye's Avatar
i removed the 2 connectors from my broken NAK deck (unsoldered) and use them to make a harness for the Kenwood DX9140
soldered all the Kenwood wires on and just plugged it in
worked well
mark
Old 01-22-13, 05:51 PM
Jason509
Jason509's Avatar
do you know what wires are what in the stock harness? i have the nakamichi and bought the adapter the person said i needed on the tutorials but it doesnt work with nakamichi..
Quick Reply: HELP!!! Question about installing aftermarket radio to replace broken nakamichi
