Need Help..1990 LS400 Too Low In Rear
i need help with getting my ls400 lifting in the rear. i have no idea what part i need. the guy i bought it from took the springs out. one person said i should get spring spacers. but i just need a run down of all the parts i would need. try too keep it cheap as possible..thanks
Rubber spring spacers would be your cheapest option. They would run you about $8 for a 2" lift. If you want a stronger lift use 2 of them on each side of the car.
Used them on an old Taurus I had and it worked great.
Do you want the car back to stock height? How in the devil are you driving
a car with no rear springs? Those units are shock-spring combinations. Just
go to a junk yard and get replacement units out of a wrecked car. That's
what I did in an effort to raise my rear end.
LS400Club
39
04-16-16 03:51 PM
