UCF20/21 front brake caliper into UCF10/11?? (The Mother thread)
Old 05-01-07, 04:11 PM
ctscna1
ctscna1's Avatar
Default UCF20/21 front brake caliper into UCF10/11?? (The Mother thread)
What part do i need to put the 95+ 4 piston caliper into the 91?
spindle, rotor, caliper and bigger wheels? Anything need to customize?
I have search on it but only found info the Supra TT conversion only.
For the Supra conversion, is it just direct bolt on to the original spindle or need to have adapter to complete the installation?
Last edited by RA40; 03-23-14 at 02:43 PM. Reason: descriptive title & multiple threads merged
Old 05-01-07, 04:42 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
same install as TT, all bolts right in aside from having to cut/bend the dust shield which you'd have to do with either setup.
Old 05-01-07, 05:03 PM
ctscna1
ctscna1's Avatar
Is someone said the spindle or hub was different between the 90-94 and 95+. So do i need to get the spindle or hub?
Old 05-01-07, 05:10 PM
PureDrifter
BahHumBug
no. u need the 2LS calipers+pads+shims, 2LS rotors, and id just get some SS lines from goodridge at the same time.
Old 05-01-07, 05:17 PM
ctscna1
ctscna1's Avatar
Thank you so much for your great info
Old 05-01-07, 10:04 PM
avalon42
avalon42's Avatar
Listen to the wise one (PD), he has been here way too long and knows all...
but if you're looking for the 2LS caliper kit, ALIGA (that's his screen name) has used ones for sale. The pads rotors and stainless steels lines are separate of course.
I'm saving up $$$ rite now, but I'm doing the electric fans conversion first...
Old 05-22-07, 09:13 PM
ctscna1
ctscna1's Avatar
I tried to put it on today and the caliper was hitting the tie rod or the steering knuckle. Do i need to get the 95+ steering knuckle/spindle or i need to modify something?
Old 05-22-07, 09:47 PM
PureDrifter
BahHumBug
richonenz was saying something about how the LS caliper being a tad wider than the TT and having to secion out part of a bolt or something.
lemme see what i can find...
Old 05-22-07, 09:57 PM
PureDrifter
BahHumBug
https://www.clublexus.com/forums/sho...d.php?t=231228
https://www.clublexus.com/forums/sho...d.php?t=274695
could u take a pic or 2 of where its binding please?
Old 05-22-07, 10:53 PM
ctscna1
ctscna1's Avatar
I will try to take a picture on the weekend so maybe you guys can find the problem.
Old 05-22-07, 11:04 PM
richonenz
richonenz's Avatar
The LS calipers are longer than the Supra units , that is they go around a bit more , you will need to get the later [ 95 to 00 ] bottom ball joint arm that bolts to the bottom of the strut and takes the steering ball joint , even here in Aus they are only bout $85.00 so over there they should not cost much .
the pic shows what I'm talking about , the earlier arm has a step in it and the newer arm does not .
Attached Thumbnails UCF20/21 front brake caliper into UCF10/11?? (The Mother thread)-caliper-95-.2.jpg
Old 05-23-07, 10:28 PM
ctscna1
ctscna1's Avatar
does the 95 lower ball joint bolt right on to the 91 spindle? how about do i need to change the tie rod end?
Old 05-23-07, 10:43 PM
ctscna1
ctscna1's Avatar
Here is the picture for binding
Old 05-23-07, 10:50 PM
PureDrifter
BahHumBug
you need to get the lower balljoint arm described by richonenz above
Old 05-23-07, 11:18 PM
richonenz
richonenz's Avatar
CTS everything else is the same and fits .
Quick Reply: UCF20/21 front brake caliper into UCF10/11?? (The Mother thread)
