TPS and trac light help
Old 04-30-07, 01:12 PM
omarg
omarg's Avatar
Default TPS and trac light help
Ok so i thought my idle was a little low so i followed the LexLS on adjusting it. Well I finish and now i have the trac light is on! what happened?
Old 04-30-07, 03:02 PM
omarg
omarg's Avatar
nevermind! I'm an idiot. I didn't realize i adjusted the trac throttle position sensor. I didn't realize there where two and i adjusted the wrong one!
I really need to pay more attention!
Old 04-30-07, 08:04 PM
ls4gs4ownr
ls4gs4ownr's Avatar
Please post the results of your TPS adjustment. What was your initial and final idle speeds with the AC on and off. I have a similar problem with low idle speed. I'm not sure whether to adjust my TPS or replace and adjust a new TPS. No codes present.
Old 04-30-07, 10:00 PM
omarg
omarg's Avatar
Umm i didn't adjust it. I was going to but i was so happy about fixing the trac light i put my tools away. The only reason i was gonna adjust my TPS was because when the car is in drive and stopped i get a very very minor vibration in the steering wheel and seatback. I'll adjust it sometime this week and post my results.
If you have a low idle just adjust the TPS a bit clockwise and see what happens. Make sure your sparks and wires are good though. That can cause a lower than normal idle.
2000ES300
01-18-08 05:18 PM
OlschoolGs
Performance & Maintenance
04-23-05 12:57 PM
JamesN
02-25-05 09:31 AM
slash
14
11-17-04 01:16 PM
Quick Reply: TPS and trac light help
