Rear brake pads 94' LS
Old 04-19-07, 03:02 PM
Bri-Guy
Bri-Guy's Avatar
Default Rear brake pads 94' LS
I need new brake pads for my rear brakes in my 94 LS 400. Where do you all suggest buying these from? I've got a mechanic who will do it for $125 (parts and labor). But I 've seen the pads much cheaper on the net. I'm a realtor, drive alot, and don't want to buy the cheapest, but also am not looking to "trick out" my brakes either.
Thanks!
Old 04-19-07, 04:14 PM
omarg
omarg's Avatar
just buy some midgrade pads from autozone and have your mechanic charge you the 60-90 in labor. That way you get oem replacement pads instead of the cheapest stuff (what your mechanic will probably put on your car). Win-win.
Old 04-20-07, 05:05 AM
pito
pito's Avatar
My mechanic charges maybe $40 labor for back brakes. Use that as a reference.
Old 10-21-08, 12:01 PM
BIGBADDAD
BIGBADDAD's Avatar
I have a question about my 1994 LS 400 rear brakes....they are disk/drum. Does any one know where to buy the rotors and pads/drum liners? I pulled them apart to replace the pads, and to my surprise I found a set of drum brakes inside???
Thank you for any info you can supply.
Mark
Old 10-21-08, 12:13 PM
avalon42
avalon42's Avatar
Mark
Drums and disk brakes are 2 different things and do not look similar at all. What are you referring to?
Old 10-21-08, 02:16 PM
Kansas
Kansas's Avatar
The brake shoes on the rear parking brake drums almost never require replacement. On my 2000 LS400, the brakes shoes are OK if the lining thickness is above 1 mm. Since the parking brake drums and shoes almost never require service, most people probably don't even realize they are there as they are on most cars with rear disk brakes.
Old 10-21-08, 03:11 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
the LS' rear brakes (as well as many other cars) use a disk/drum setup in which there is a small drum brake inside the rotor.
lexus600hl
04-15-13 05:34 PM
Rob6656
10-23-12 11:59 PM
GregCon
06-04-12 09:46 AM
Bigrahizzl
Suspension and Brakes
08-26-10 04:11 AM
gebo
09-20-01 04:38 PM
Quick Reply: Rear brake pads 94' LS
