NEW Nagisa Auto Suspension Parts for the UCF2#
Old 04-07-07, 09:06 AM
Tanabe USA
Former Vendor
Tanabe USA's Avatar
Exclamation NEW Nagisa Auto Suspension Parts for the UCF2#
Tie Rod Ends
These pillowball tie rod ends are designed to hinder the effects of bump steer when the front wheels toe out excessively over bumps.
The Nagisa Auto tie rod ends will allow significant adjustment and correction of front end steering and suspension geometry.
Front Camber Adapter
Lowers vehicle 20mm
Connects to lower arm
Adds negative camber angle 2.5 - 3.0 degrees
Front Tension Rods
Replaces stock tension rods with reinforced units with solid pillowball ends.
May be used for Caster angle changes.
Factory tension rods use a rubber bushing which tends to wear quickly and affect handling stability. Adjustable pillowball ends allow for adjustment beyond factory settings.
Multi-link suspension pieces feature high quality construction and durable spherical pillow ball ends, which eliminates factory rubber bushing type suspension arms.
Front Upper Arms
The Nagisa Auto Front Upper Control Arm replaces the OEM piece with a much stronger unit with spherical pillowball joints.
This can be used to adjust or correct alignment settings after lowering the vehicle, and for aggressive race setups.
Large adjustment range.
This is a unique design that is vastly different from other bulkier designs that are currently on the market.
Pillowball joints provide zero deflection, and is ideal for pure track use.
*For pricing inquiries please contact the forum sponsored vendors.
*For dealer inquiries please contact info@more-japan.com or call toll free at 1-888-560-4800.
Tanabe USA is offline
Old 04-07-07, 09:21 AM
RA40
Super Moderator
RA40's Avatar
WOW...nice parts
RA40 is offline
Old 04-07-07, 12:26 PM
pito
pito's Avatar
DAAAAAAAAAAAAAAAAamn
What prices??????????
pito is offline
Old 04-07-07, 06:01 PM
RA40
Super Moderator
RA40's Avatar
Click the pic for the details.
Quality goodies come with a matching price.
RA40 is offline
Old 04-27-07, 02:33 AM
bunta
bunta's Avatar
where does the front camber adaptor go?
bunta is offline
Old 04-27-07, 03:25 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
lower control arm + wheel hub assy. iirc
PureDrifter is offline
Old 09-05-07, 07:04 PM
fujimoto
fujimoto's Avatar
Will any of those parts fit a UCF10?
fujimoto is offline
Old 09-05-07, 07:12 PM
LiCelsior
Retired
LiCelsior's Avatar
nope , only parts from UCF1X will fit on UCF2X.
LiCelsior is offline
Old 09-05-07, 08:52 PM
PureDrifter
BahHumBug
i dont remember seeing the REAR "camber adapter" on more-japan
and if anyone's wondering, yea, its very similar to the YouZealand SS kit
(^except it costs more a bit >.>)
Old 09-06-07, 08:13 PM
fujimoto
fujimoto's Avatar
Confused.
The 2LS parts will fit my UCF11, but not the other way around?
fujimoto is offline
Old 09-06-07, 08:15 PM
LiCelsior
Retired
LiCelsior's Avatar
no no no, the 1st gen parts fit on 2nd gens but 2nd gen parts cannot fit on 1st gens.
Old 09-06-07, 09:25 PM
PureDrifter
BahHumBug
Originally Posted by fujimoto
Confused.
you all realize that htis rule applies ONLY to shocks+springs/coilover assemblies right? its only one way compatible because of the longer piston length on 2LS struts which bottom out too quickly and prematurely die when used on 1LS.
mk4r34
Suspension and Brakes
06-25-10 12:52 AM
Tanabe USA
51
03-16-09 01:40 PM
Tanabe USA
SC- 1st Gen (1992-2000)
04-10-07 05:04 PM
Tanabe USA
04-04-07 05:28 PM
Tanabe USA
12
04-02-07 06:43 PM
Quick Reply: NEW Nagisa Auto Suspension Parts for the UCF2#
