How to connect JDM Headlight wiring harness to USDM Headlight wiring harness?
Old 03-23-10, 11:22 PM
Legionofon
Legionofon's Avatar
Wait whats the different between the JDM lights and the USDM ones? they look identical to the ones i have on my 93...
Old 03-23-10, 11:27 PM
j stuff
j stuff's Avatar
the fogs and the headlights of the USDM are separate. JDM ones are combined into one piece.
Old 03-24-10, 12:10 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
the lens is 1 pc, instead of 2. looks cleaner.
plus they use H4 bulbs, and have much better light output and pattern than the USDM 89-92 lights (93-94 are H4)
Old 03-24-10, 12:11 AM
Legionofon
Legionofon's Avatar
lol its hillarious the tiny changes they make between JDM and USDM
Old 03-24-10, 08:40 AM
j stuff
j stuff's Avatar
i have no idea why up till now car companies do this! Why not just make everyone's 1st gen, worldwide 1 piece? It just seems easier to me
Old 03-24-10, 09:50 AM
PureDrifter
BahHumBug
because every country has different requirements in order, and in the US they were just retarded in the late 80s/early 90s. think back, remember any car before 92/93 that had anything resembling decent lighting?
Old 03-24-10, 10:49 PM
Garage7RP
Garage7RP's Avatar
You could be right. Also, it may not be wired properly and is only receiving half the power. Just look for the H4 harness.
Originally Posted by j stuff
Hm would the h4 specific harness fix the problem I have?
Problem: Noticed passenger side headlight was dim. Decided to change both bulbs. After install, pass side still dim. I remembered it looked like a crappy wiring job was done on that side. Previous owner must have broken the oem wire harness.
Im thinking that its not h4 specific so it does not have enough power to run the battery at full strength.
Can anyone verify if that could be right?
Old 03-24-10, 10:51 PM
j stuff
j stuff's Avatar
thanks for the reply garage. I purchased the h4 harness @ Oreilly and it looks much more similar to the OEM than what I found in the passenger side headlight area.
Hope this works, will report in
Old 07-17-17, 04:18 AM
BosmanM
BosmanM's Avatar
Hey any links on ebay for the wiring harness? The one you mentioned does not exist anymore.
Tigger240
06-21-17 05:12 PM
DBO617
04-08-13 08:27 AM
mkiiisupra
GS - 1st Gen (1993-1997)
15
05-14-10 07:21 PM
one30boy
08-16-04 06:22 PM
bmsport
Performance & Maintenance
09-18-03 04:25 PM
Quick Reply: How to connect JDM Headlight wiring harness to USDM Headlight wiring harness?
