PS parts, help me get all I need...
Old 02-07-07, 12:02 AM
Hit Man X
Hit Man X's Avatar
Thumbs up PS parts, help me get all I need...
Hey all -
PS pump finally took a duke and am going to replace all minus the rack here. I'm looking for part numbers on the low pressure return lines, the vac lines in there, etc. Any tidbits/info are welcome.
I've read I can remove that check valve and go without (like on the SC), any downside to this? Seems to alleviate potential future issues as well as save a few beans in the process.
Old 02-15-07, 04:01 AM
Hit Man X
Hit Man X's Avatar
Thumbs up
Bump, help is still needed for the hoses.........
Old 02-18-07, 04:34 PM
1996LS400
1996LS400's Avatar
You can goto lexuspartsonline.com and put in your vehicle info. Then go to steering and it will show you parts and part#s.
Hope it helps!
Old 02-18-07, 06:29 PM
avalon42
avalon42's Avatar
I just removed my idle up air valve. Boy, that old PS fluid in there is GROSS! Chunky and brown! I thought I was draining a septic tank on an RV.
Anyhoo, I noticed I was leaking power steering fluid from this point so I went to Kragen and got me a M14 1.50mm short bolt (shorter than the length of the original idleup valve for only $2.47. The vacuum caps cost only $2.50. Cheap solution for a $120 dealer part.
I didn't notice the idle drop down at all. Thank you Club Lexus and its members for teaching me how to save money and fix stuff myself! Now if I could only save up enough dough and rack my brains to do my timing belt...
Old 02-19-07, 07:10 PM
avalon42
avalon42's Avatar
Ok, I did notice that power steering went down a bit, but its more to my liking. I never liked how loose the power steering was before. It's stiffer now, and the idle is down a notch.
Old 02-20-07, 09:43 PM
Hit Man X
Hit Man X's Avatar
Thumbs up
So no one can provide part numbers for the return line off the rack or any of the vac lines?
theschoens
48
10-28-18 05:29 PM
dcz
11-09-13 03:36 PM
xx69xx
SC- 1st Gen (1992-2000)
13
04-26-10 12:03 PM
hp32si
01-09-10 03:42 PM
groove
01-06-06 09:45 AM
Quick Reply: PS parts, help me get all I need...
