Camry Power antenna???
Old 01-24-07, 05:44 PM
bsouth123
bsouth123's Avatar
Default Camry Power antenna???
Well my gears in the Power antenna are stripped and I need a new one. I found a new OEM version for $215. I started to search for a 1992 Camry part and it is HALF!
Will it work??
Old 01-25-07, 10:46 AM
akxx
akxx's Avatar
All you likely need is a $20 antenna mast with toothed cable. You will likely need to disassemble the motor housing to replace--a little elbow grease, but much cheaper.
Do a quick search on this forum--should be many links to it.
Old 01-25-07, 01:16 PM
bsouth123
bsouth123's Avatar
I don't think a new mast will work. The gears that turn from the motor itself are thinnned to the point they don't catch.
Old 01-26-07, 10:40 AM
akxx
akxx's Avatar
I saw an aftermarket motor/mast assembly on ebay for the LS400 for 30 or 40 bucks...not sure of the quality though.
AlaskanLS
07-01-17 10:51 PM
cda888
06-05-05 04:41 PM
cleoent
25
12-06-04 05:22 PM
DA51
12-04-02 12:25 AM
mdfdsc300
SC- 1st Gen (1992-2000)
04-19-01 03:07 AM
Quick Reply: Camry Power antenna???
