1990 transmission trouble.
Old 10-12-06, 02:00 PM
moons70
moons70's Avatar
Default 1990 transmission trouble.
any idea's, i,ve a 1990 LS with 200k on the clock. recently the o/d light comes on and when it does the box does not change down when the throttle is pressed. Switching the ignition off for a few minutes cures this but a few days later its back. I know that Dexron is in the box and i'm due to put toyota oil in but was wondering if any you guys had similar trouble. look forward to hearing from ya's. B
Old 10-13-06, 08:55 AM
persian451
persian451's Avatar
put only Toyota T-IV or T-II trans fluid in your tranny
Old 10-13-06, 01:25 PM
moons70
moons70's Avatar
will do. hopefullt it will improve. thanks...
Old 11-20-06, 06:24 PM
Sterling
Sterling's Avatar
Had similar problem, the wire on one of the shift solenoids inside the transmission had a bad solder joint. Re-soldered and fixed the problem.
Rice
09-02-10 09:26 PM
Mr.lex89
12-08-09 05:42 PM
dthouston
06-17-08 09:41 AM
BWARD
11-03-05 01:38 PM
MellonC00
RX - 1st Gen (1999-2003)
08-05-05 10:56 AM
Quick Reply: 1990 transmission trouble.
