Fixed Low Idle Speed Problem
Old 04-15-15, 11:02 AM
  #31
dicer
dicer's Avatar
Originally Posted by mattylex77
im getting desperate. My 99 idles at 200 rpm in D without lights or AC. Cant seem to fix it and its really bugging me.
would this work for the 99? Are the power steering lines the same as a UCF10??
I think VVT adds another variable to it. The cams are advanced and retarded and could change idle speed too.
Old 04-15-15, 12:01 PM
  #32
Legender
Legender's Avatar
I had the same problem on my old 1995... I found the problem was exacerbated after a long drive and when pulling off the highway the car would die. I cleaned out the throttlebody and found it to be much better and the stalling quit.
FYI... I just did the IACV delete onmy 1998 when I replaced the power steering pump, but don't recall if it made much difference. It had already fried the alternator before I bought it. And yes, the power steering vacuum lines are at least the same on my 1998.
Don't underestimate the impact of cleaning out that throttle body.
Old 04-16-15, 05:05 PM
  #33
Yamae
Yamae's Avatar
How did you delete it? There is no IACV for a 98.
Old 04-16-15, 06:05 PM
  #34
Legender
Legender's Avatar
Oops. I meant the power steering air control valve on the ps pump
Old 04-16-15, 06:27 PM
  #35
Yamae
Yamae's Avatar
I understand now. Initially I wondered why you wrote that since I always find your posts are quite nice and informative.
Legender (03-22-18)
Old 08-19-17, 01:24 PM
  #36
LexVoitek
LexVoitek's Avatar
Cool Your Electric Throttle Body Is Causing Low Idle I Have Proof!
I have an 06 Lexus GS300 that had the Lexus GS & IS Engine Misfire Recall CSP performed in 2012. Last year I noticed that in hot humid weather with the AC on, my idle began fluttering. Since it only happened a few times last year, I wrote it off as a fluke. This year however, the RPMs dropped to 500 or below, triggering the infamous "Check VSC" and "Check Engine Lights". I used a bluetooth code reader and noticed that the car was throwing engine misfire codes in addition to P0505 Powertrain Idle Control System codes. My first thought was that the car needed to have the carbon buildup cleaned again, whcih would costs thousands at the dealership. Luckily, I found people with electronic throttle bodies saying that once they cleaned theirs, the problem was fixed.
Well to make a long story short, I decided to clean my electronic throttle body myself, even though there's been reports of people breaking their $700 throttle bodies in their attempts to clean it. I recorded the whole process, for my youtube channel and of course for Club Lexus members Enjoy, I learned a lot from the process, including scaring myself to death when the butterfly door didn't seat properly.
BTW: I have a whole Lexus Service playlist on my channel which includes dealer footage of the carbon cleanup CSP.
The following 2 users liked this post by LexVoitek:
SmokeLex (08-20-17), spuds (03-17-18)
Old 12-19-18, 02:08 AM
  #37
OmariMack
OmariMack's Avatar
Thanks Jayjw!, I had a same problem with low idle speed, I will try swapping hoses by tomorrow
I will give you update
Team Ls400 lol
Old 01-06-22, 05:30 PM
  #38
95celsiorg
3rd Gear
95celsiorg's Avatar
Years late, but ill try this one out. My 95 UCF21 has been giving me fits. Next resort is getting the IACV cleaned and replacing TPS and MAF. Already rebuilt the ECU, wish that had been the problem haha.
Old 01-07-22, 09:45 AM
  #39
timmy0tool
timmy0tool's Avatar
here is another helpful link to checking out the IACV:
https://planetsoarer.com/IAC/iac.htm
hms09
18
01-15-17 08:28 PM
Techmotion
09-17-13 06:53 AM
steventnm
06-25-12 08:23 PM
clean
Performance & Maintenance
07-17-07 07:23 PM
Eric00GS3
Performance
08-17-06 08:18 AM
Quick Reply: Fixed Low Idle Speed Problem
