Running Power wire on a 2nd gen LS
Old 09-14-06, 01:20 PM
LEXBUBB0
LEXBUBB0's Avatar
Default Running Power wire on a 2nd gen LS
I was wondering if anyone has any pics on running power wire for amps on their LS. ThankYou
Old 09-14-06, 02:56 PM
Alan D
Alan D's Avatar
I had a really hard time running one from the battery to the trunk on my 99. Hooked the fused connection to the battery terminal and then ran in down the radiator shroud to the frame rail underneath the car. There is a rubber plug in the floor in front of the driver's seat. Came into the cabin through there and then ran through the door sill molding to the back seat. Found a plastic plug with wiring leading to the trunk so I went through there. It's at the top of the drivers side rear seat back.
Old 09-14-06, 04:14 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
http://babelfish.altavista.com/babel...d_changer1.htm
2nd, 3rd, and 4th links when u scroll down.
Old 09-14-06, 05:39 PM
Lexkost
Lexkost's Avatar
Best spot is through the AC boot .
Old 09-14-06, 11:23 PM
skperformance
skperformance's Avatar
Mine sounds like Alan's . It goes in a small hole in the fender behind the dead stop then enters the car through the rail and pops up beside the carpet and the drivers seat. Goes through the same area behind the upper of the rear seat.
greywolf40
09-07-12 11:17 PM
$hogunn
SC- 1st Gen (1992-2000)
03-22-10 05:03 PM
paulg123
10-13-08 08:52 PM
chubby
10-12-07 10:47 PM
mase
01-26-06 08:48 PM
Quick Reply: Running Power wire on a 2nd gen LS
