Rear Knuckle bushings - source (pic attached)
Old 01-20-11, 11:48 AM
  #31
fencera
fencera's Avatar
I got the silicone lube from Summit Racing.
The oem version of the Adus 5056 (48725-22110) is available from Lexus of Pembroke Pikes for $19.80 each with about $5 in shipping.
Old 01-20-11, 12:58 PM
  #32
williamb82
williamb82's Avatar
ill check out summit. as for the stock bushings. no thanks. i prefer urethane. much firmer and lasts alot longer as well. i plan to replace all bushings with urethane as i can afford to.
edit: this is the stuff looks like a winner to me. i plan to drill and tap all the bushing locations for zirk fittings. this'll make it nice and easy to grease them. plus the bushings have a gap between them that shohld hold grease with no issues. the stuff you mentioned doesnt come in tubes for a grease gun.
http://www.summitracing.com/parts/PTP-19-1751/
Old 01-20-11, 02:06 PM
  #33
Coulter
Coulter's Avatar
Just wanted to know what the effect on ride quality the ADUS polyurethane bushings had. I'm replacing the original rubber rear knuckle bushing (#2 on the diagram). I like the smooth Lexus ride and was worried the poly would make the ride bone-jarring stiff.
Was there a dramatic increase in stiffness?
Thanks for the info.
Old 01-24-11, 04:57 AM
  #34
williamb82
williamb82's Avatar
well ,since i went from no bushings to urethane, my ride got better. then again, i also dont like a mushy ride. with all poly bushings it wont be bone jarring unless you put some stiff coilovers in.
Old 02-27-11, 09:31 AM
  #35
CDriver
CDriver's Avatar
Can someone mic the bushings and sleeve that go into the knuckle? I have an 02 GS300 and want to see if this will work for my app.
Old 02-27-11, 11:47 AM
  #36
brianmch
brianmch's Avatar
Before the flames start, I'll say I've not found the answer yet...which is why I'm asking here.
Since we're talking rear end, anyone know anything bout rear upper control arm ball joints? I need them for my 99 w/185K on the clock and don't want to spend for new arms when I just need the ball joints.
TIA
Old 02-27-11, 12:08 PM
  #37
williamb82
williamb82's Avatar
the ball joints are part of the upper control arms
Old 02-27-11, 12:56 PM
  #38
brianmch
brianmch's Avatar
So I'm taking that to mean that they can't be replaced independently of the arms?
Old 03-16-11, 05:18 AM
  #39
williamb82
williamb82's Avatar
no, they cant. they are part of the arms. when the ball joint goes bad, you must replace the control arm. this will be the case until a company makes an arm with replaceable balljoints. im sure techno toy tuning could do it, but wether they would or not is a different story.
Old 03-16-11, 10:40 PM
  #40
Garage7RP
Garage7RP's Avatar
Thanks for the great info and write-up.
Old 10-30-12, 08:37 PM
  #41
305ls400
305ls400's Avatar
where did you buy the bushing
Old 10-31-12, 10:24 AM
  #42
McPierson
McPierson's Avatar
Does anyone have this information for 98-00 LS400?
Old 10-31-12, 03:32 PM
  #43
PureDrifter
BahHumBug
PureDrifter's Avatar
same setup for the rear carrier bushing.
Old 10-31-12, 07:05 PM
  #44
McPierson
McPierson's Avatar
Have you tried the 5056 into the arm of a 2.5LS? Vincent and Ray said in this thread: https://www.clublexus.com/forums/ls4...m-bushing.html that the 5056 didn't fit into the rear "strut rod" (in the rod not attached to the knuckel). There were a few other threads that seemed like there were questions.
Old 10-31-12, 08:36 PM
  #45
PureDrifter
BahHumBug
no idea on the 5056, i was talking about the carrier arm bushing that gets swapped for the ADUS 505 as that's what the knuckle bushing is.
Quick Reply: Rear Knuckle bushings - source (pic attached)
