Coilover noise, anyway to keep it quiet??
Old 08-16-06, 04:14 PM
georgets
georgets's Avatar
Default Coilover noise, anyway to keep it quiet??
I know coil overs are noisy. But is there any product out there to keep them quiet? Running over bumps on my advox I can hear clunking noise. It does get annoying in a quiet cabin like the LS. The alignment tech after driving my car said "it's a good car, except for that aftermarket suspension crap that keep making noise...".
Does anyone with Blisteins and eibach spring have any noise on their cars?
Old 08-16-06, 04:40 PM
RA40
Super Moderator
RA40's Avatar
I've got spring slap on one of my rears and have just been lazy to put an insulator on it. The front clunk on mine is likely caused by a worn control arm bushing. (Having replaced the lower ball joints, tie rod ends and strut bars already.) Beyond that...
Old 08-16-06, 04:42 PM
steveski
steveski's Avatar
I have Bilsteins - every now and then the clunking noise is audible. Some say it's bushings (control arms) or ball joint(s). I took it to the mechanic and all of those possible causes were not worn out in my case. So far I am just living with the occasional clunk since nobody knows what it is
Old 08-16-06, 05:04 PM
Suneet
Suneet's Avatar
I have a clunk from my left front wheel after installing Tokico struts. Its the only strut that I didn't compress the spring myself. I had that one compressed at Wheel works (the others were compressed by them but not aligned properly, so I ended up learning how to do it and compressing them myself anyways.. waste of $50)
The clunk only happens when I take hard right turns, or if I jack up the car. So I know it is related to the way the spring is sitting on the strut. I've just been too lazy to fix it. I'd have to take the strut out and recompress the spring and then realign it.. PITA.
Old 08-16-06, 05:35 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,119 Likes on 1,293 Posts
I had the L-sportline setup (Eibach / Blistein) and just went back to OEM partially because the clunking noise annoyed me and partially because of the harsh ride.
There are two things you can do... an insulator or put some hosing around the springs. This thread covers both.
https://www.clublexus.com/forums/sho...d.php?t=163670
Old 08-16-06, 05:51 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
hey dave, selling your LSportline setup
Old 08-16-06, 06:07 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Yep, sure will be. Got 'em sitting in the garage - need to research selling price.
I hate shipping, so hoping to try to sell them locally first for pickup (low probability but I'll try).
Old 08-16-06, 08:20 PM
PureDrifter
BahHumBug
alright, hit me up when u put em for sale pls
also, hows the adjustability on the LSportline susp. compared to the JIC SF-1 and Tein CS?
Old 08-16-06, 08:23 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
I know they're supposedly adjustable, but I just had them installed at the medium setting and the car was still pretty low, especially in the back.
I never adjusted them once installed so can't speak to it, but I seem to recall there were three adjustment points. A coilover setup is going to give you a whole lot more flexibility in up & down 'clicks'.
Old 08-16-06, 08:59 PM
RA40
Super Moderator
RA40's Avatar
Pure-
I'd strongly suggest the adjustable SF-1 or CS. I've about had it with the uneveness of the spring strut combo on mine...it's liveable but it wears on me. That 3/8 gap in the right rear is
B1gredek had the LSportline on his at the lowest setting. At the LuxuryMods VIP meet, he said it was pretty stiff. The car is now on bags.
Old 08-16-06, 10:23 PM
Pagong
Pagong's Avatar
Go air!!!
I only get the clunk noise when I have my JIC's cranked all the way to the lowest setting, which I dont recommend doing. But looks soooper dooper ...
Old 08-16-06, 10:29 PM
PureDrifter
BahHumBug
he has the UCF21 with the Q45 gatling gun headlights and 20s right? nice car that is.
my only thing right now is that the FLT-A2s are what JIC sells but are between 1800-2000, the NEW CS is about 1200 but nobody has it for the LS4 yet, and the SF-1s are kinda on my mind because its about $250-300 to rebuild them since il HAVE to buy them used.
thoughts? opinions? anything?
Old 08-17-06, 04:59 PM
RA40
Super Moderator
RA40's Avatar
Sorry to the original poster...about the noise issues.
Anyway...if the SF-1's are available (Vince's?), and you don't want to wait for the CS, have them rebuilt. The shop is local (Downy I believe) so turn-around shouldn't be bad if it doesn't require a part to be shipped from Japan.
Have you contacted Steve at Carson about the CS for ours?
Old 08-17-06, 05:10 PM
PureDrifter
BahHumBug
i talked to Luis and he said theyv had them on order since the new CS first came out but no ETA yet.
i wouldnt mind the SF-1s but again, im looking at 250+ for each corner just in PARTS! thats over $1000 just in a REBUILD and not including the price of the coilovers. at that point im better off finding a set of new FLT-A2's.
im prolly gunna end up buying used coilovers but have this fear that once i get them, il have them for a month, then a shock will blow or something :/
Old 08-17-06, 08:53 PM
RA40
Super Moderator
RA40's Avatar
I'd wait for a fresh set of CS or A2's then.
Quick Reply: Coilover noise, anyway to keep it quiet??
