93' LS possibly power steering issue......
Old 07-31-06, 07:50 AM
AZDesertGS
AZDesertGS's Avatar
Default 93' LS possibly power steering issue......
I'm having a little bit of an issue and maybe it is well known so I wanna see what you LS experts think. When I am coming out of a parking spot, obviously at slow speeds, it feels like my tires are rubbing, when I am turning the steering wheel... but I know that they are not. I have a feeling it has something to do with the power steering. So I don't know if it is the belt slipping....the steering rack is going bad.....or what. The tires rubbing is the best way I can describe what it is doing.
Anyone ever experience this before.
Also fyi...the fluid is fine and is at the correct level.
Thanks
Old 07-31-06, 08:10 AM
Tammy
Tammy's Avatar
You'll have to put the front end on jack stands or a lift. It's the only way to check the smoothness of the rack, along with the ball joints, A-arms, tie rod ends, rubber mounting bushings.
With the mileage, this may indicate multiple points of wear .
Old 07-31-06, 10:08 AM
KilaWombat
KilaWombat's Avatar
I started experiencing this as well eversince after I had my upper control arm bushings replaced...
Thanks
Old 07-31-06, 11:50 AM
AZDesertGS
AZDesertGS's Avatar
That sucks......you fix one thing and something else goes whacky. Hopefully some others chime in
Bon
08-13-21 07:51 PM
Stroock639
01-31-20 07:40 PM
theRain04
12-02-15 05:48 AM
BoostAddct
Suspension and Brakes
17
10-28-11 09:29 PM
syntax
02-09-11 12:31 PM
Quick Reply: 93' LS possibly power steering issue......
