So I'm picking up a 1994 LS400 with 98k miles on saturday.
Originally Posted by PureDrifter
i thought u said that the car has 98k mi on it
jsut make sure u get the carfax for the car.
01/23/1994 NICB Vehicle manufactured and shipped to original
dealer
06/22/1994 62 Delaware
Motor Vehicle Dept.
Wilmington, DE
Title #00031666 Title or registration issued
First owner reported
07/04/2001 54,827 Delaware
Motor Vehicle Dept.
Wilmington, DE
Registered as lease vehicle
11/15/2002 Delaware
Motor Vehicle Dept.
Wilmington, DE
07/15/2003 75,703 Service Facility Vehicle serviced
10/23/2003 Connecticut
Motor Vehicle Dept.
Greenwich, CT
Title #027809412 Title issued or updated
06/01/2006 Dealer Inventory Vehicle offered for sale
So, as you can see between 1994 and 2001 it only racked up 54k miles, which sounds low. I know there are shady shops that roll back mileage, and I hope this isn't the case with this car.
Originally Posted by Och
Thanks for the advice, will do.
Also, what is a good way of determining whether the odometer has been tampered with? The car has been owned by the same person from 94 to 2001, and only racked up 50,000 miles during that time. Sounds kind of low for 7 years, but it was in Delaware, which is a tiny state, so I guess it was driven for long distances.
Common issues:
Check for leaks in PS pump
check the rack & pinion
Listen for ticking in the engine (sign of needing a valve adjustment)
Climate control LCD burn out (nothing major)
Instrument cluster freezing (again, nothing MAJOR)
Those are the majority of what I've seen/heard......
Never the less, good luck with your transaction, let us know how it goes..
So in 2001 it was a lease vehicle, who would lease a 7 year old car, crazy. I wouldn't worry about the history too much, if the car is mechanically sound then you should be fine. It's a 12 year old car, you can't expect it to be perfect.
Ok, so I picked it up, took her home, she drove for over 1,200 miles without any drama. Drives great, no funny noises, smooth, quiet, very good condition. There a label on the engine stating that timing belt maintenance was performed at 80,xxx miles, it has a set of almost new tires, the suspension is nice and firm, no clunking noises, steering is great, steering wheel stay straight, doesn't pull to any side. The car is very quet, the only noise coming in is wind noise, which is understandable, these old boxy designs aren't very aerodynamic. The leather is great, not a single crack! I think the front seats were probably re-upholstered recently, because they are even in better condition that the back seat.
But I do however have a couple of concerns.
1) The car is majorly lack acceleration whatsoever - it feels like 0-60 is over 10 seconds. Is it suposed to be this way? The engine doesnt make any bad noises, doesnt smoke, doesnt burn oil, sounds very smooth and RPMs go upto the redline without any pinging, but the acceleration just plain sucks. If feels slower than my old 95 Civic with 1.5 engine, and is no match for my GS430. Once its upto highway speeds, its very adequate, for instance 60-90 is very smooth and decent, but take off just sucks. Also, I averaged over 20mpg, driving 80+ mph all the way.
2) Theres no cd player!!! Only AM/FM/Casette. I can't believe Lexus ever came without CD. I'm gonna look into adding an external cd changer or i-Pod.
3) Both front seats are a little loose. I had the same problem in my old 94 GS300. Is there an easy fix?
BahHumBug
1-the first gen was a SLOW car. that being said it isnt really a slow car. now that thats outta the way; try resetting the ECU (unplug battery for 5-10 mins), oil change, plug change, and other basic maint. stuff. ( the ecu reset should help a lot).
2-for the 1st gen cars i believe it was an option, and it was mounted in the trunk as a 6 disk changer.
3-this may help?
http://www.cureline.net/lex/howtos/info_seats.htm
3-this may help?
That being said, I looked in the engine bay briefly, I couldn't located the distributor (does it have a distributor or electronic ignition?). Also, I didn't find where the plugs and wires go, are they underneath the engine?
3-this may help?
Will look into that, thanks.
marklfarkl
15
11-07-19 09:37 AM
Stereorob
08-10-18 03:16 PM
